Page 5 of 5 FirstFirst ... 345
Results 61 to 74 of 74
Thread: VLANы на WL-500W (подключение STB приставки, второй провайдер)
  1. #61
    Jan 2008
    msk
    Quote Originally Posted by andreyppc View Post
    nvram commit забываешь?;-)
    Да не, такие штуки не забываю :-)))
    Кстати, постом выше человек спрашивал что означает первая строчка, мне если честно то же интересно....
    MSK | Asus WL-500w | 299Mhz | 128Mb | ver. 1.9.2.7-10 HDD bluescorpio 160Gb int.|console|RS-232|PCMCIA My modding
  2. #62
    May 2010
    Moscow, Izmailovo
    Quote Originally Posted by Mr.Hunt View Post
    Открываем броадкомовские исходники и вот что видим:
    /* boardflags */
    #define BFL_BTCOEXIST           0x00000001      /* This board implements Bluetooth coexistance */
    #define BFL_PACTRL              0x00000002      /* This board has gpio 9 controlling the PA */
    #define BFL_AIRLINEMODE 0x00000004      /* This board implements gpio13 radio disable indication */
    #define BFL_ENETROBO            0x00000010      /* This board has robo switch or core */
    #define BFL_CCKHIPWR            0x00000040      /* Can do high-power CCK transmission */
    #define BFL_ENETADM             0x00000080      /* This board has ADMtek switch */
    #define BFL_ENETVLAN            0x00000100      /* This board has vlan capability */
    #define BFL_AFTERBURNER         0x00000200      /* This board supports Afterburner mode */
    #define BFL_NOPCI               0x00000400      /* This board leaves PCI floating */
    #define BFL_FEM                 0x00000800  /* This board supports the Front End Module */
    #define BFL_EXTLNA              0x00001000      /* This board has an external LNA */
    #define BFL_HGPA                0x00002000      /* This board has a high gain PA */
    #define BFL_BTCMOD      0x00004000      /* This board' BTCOEXIST is in the alternate gpios */
    #define BFL_ALTIQ               0x00008000      /* Alternate I/Q settings */
    #define BFL_NOPA        0x00010000      /* This board has no PA */
    #define BFL_RSSIINV             0x00020000      /* This board's RSSI uses positive slope */
    #define BFL_PAREF               0x00040000      /* This board uses the PARef LDO */
    #define BFL_3TSWITCH    0x00080000      /* This board uses a triple throw switch shared with BT */
    #define BFL_PHASESHIFTER        0x00100000      /* This board can support phase shifter */
    #define BFL_BUCKBOOST   0x00200000      /* This board has buck/booster */
    /* boardflags2 */
    #define BFL2_RXBB_INT_REG_DIS   0x00000001      /* This board has an external rxbb regulator */
    #define BFL2_DEPRECIATED_STUB   0x00000002      /* This board flag is depreciated */
    #define BFL2_TXPWRCTRL_EN       0x00000004      /* This board permits enabling TX Power Control */
    #define BFL2_2X4_DIV            0x00000008      /* This board supports the 2X4 diversity switch */
    #define BFL2_5G_PWRGAIN         0x00000010      /* This board supports 5G band power gain */
    #define BFL2_PCIEWAR_OVR        0x00000020      /* This board overrides ASPM and Clkreq settings */
    #define BFL2_CAESERS_BRD        0x00000040      /* This board is Dell Caeser's brd (unused by sw) */
    Если сложить выделенные значения, то получается ответ на Ваш вопрос.
  3. #63
    Quote Originally Posted by VicSer View Post
    /* boardflags */
    /* boardflags2 */
    А для N16 такая же цифра ?
    ASUS RT-N16
  4. #64
    May 2010
    Moscow, Izmailovo
    Quote Originally Posted by ITC View Post
    Это уже offtop.
    Если не ошибаюсь, то данная строка нужна только на WL-500W. Для RT-N16 это не надо, т.к. на нём vlan включен по умолчанию - значение boardflags=0x310.
  5. #65
    Jan 2008
    msk
    VicSer, спасибо за разъяснение, теперь буду в курсе :-)
  6. #66
    May 2010
    Moscow, Izmailovo
    Всегда пожалуйста
  7. #67
    подытожу совсем неприличным вопросом ибо о страждущих плюшек чайниках забыли. где вводить то? через путю ?
  8. #68
    В моем случае провайдер предоставляет две услуги (Internet, IPTV), но разными кабелями. Сделал LAN 3 и LAN 4 в одном vlan c WAN. WAN - Интернет, LAN 4 - IPTV, LAN 3 - Amino. И все вроде бы хорошо, НО если соблюдать последовательность включения, а именно в последнюю очередь подключать кабель Интернета в WAN, в ином случае Amino получает адрес из Интернет сети. Внимание, вопрос! Как сделать так, чтобы Amino получала адрес из своей сети?
    Да, роутер Asus RT-N16, прошивка от энтузиастов.
    ASUS RT-N16
  9. #69
    Огромное спасибо Олегу!!Супер инфа!!Долго мучился с своим роутером WL-500 W по настройке IpTv от Домолинка в г. Тула.Ничего не помогало.Даже советы из офтехподдержки.Приставка логинилась на сервер мультикаста но сам мультикаст не шёл,был чёрный экран.Напрямую с кабелем в приставку от провайдера было всё нормально.Установил последнюю прошивку Олега WL-500W firmware 1.9.2.7-d от 2011.02.19 и выполнил набор команд из первого примера.Всё заработало как часы.Мультикаст пошёл,смотрю теперь IpTV от Домолинка.Спасибо Олег!!!!Выручил!!!
  10. #70
    Спасибо за инфу
    Пробовал свой WL-500W в Билайне (Корбина) c прошивкой от энтузиастов WL500W-1.9.2.7-d-r2624.trx от 2011.02.19, при выставлении в качестве IPTV порта 4, приставка работала несколько секунд и картинка висла, переключение канала - снова работает несколько секунд и висяк. При включении мультикаст роутинга - все ОК, но Wi-Fi валится в даун. В итоге помогла прошивка 1.9.2.7-10 с настройками из первого поста. Только заработала после второй перепрошивки и двойного сброса настроек через кнопку ресет, если этого не делать - остаются старые настройки вланов.
  11. #71
    Unhappy
    Помогите пожалуйста, настроить втрого провайдера на WL 500W. Вот Примерный ход моих действий:
    Второй провайдер имеет Static IP, с привязкой по MAC-адресу.
    Шаг.1 - Основной провайдер - WAN (eth1), второй LAN1 (vlan1), компьютеры подключаю к LAN2-4.
    nvram set boardflags=0x110
    nvram set vlan0ports="1 2 3 5*"
    nvram set vlan1ports="0 5"
    nvram set vlan0hwname=et0
    nvram set vlan1hwname=et0
    nvram set wan_ifnames=eth1
    nvram set wan_ifname=eth1
    nvram set lan_ifnames="vlan0 eth2"
    nvram commit
    Шаг.2 - Делаю привязку
    mkdir -p /usr/local/sbin
    chmod +x /usr/local/sbin/post-boot
    echo ifconfig vlan1 hw ether 00:1D:BA:F2:56:E0 >> /usr/local/sbin/post-boot
    echo ifconfig vlan1 10.100.231.102 netmask 255.255.255.224 up >> /usr/local/sbin/post-boot
    Шаг.3 - Прописываю нужные мне маршруты.
    echo route add -net 10.100.0.0 netmask 255.255.0.0 gw 10.100.231.97 dev vlan1 >> /usr/local/sbin/post-boot
    echo route add -net 10.122.0.0 netmask 255.255.0.0 gw 10.100.231.97 dev vlan1 >> /usr/local/sbin/post-boot
    echo route add -net 109.197.88.0 netmask 255.255.248.0 gw 10.100.231.97 dev vlan1 >> /usr/local/sbin/post-boot
    echo route add -net 10.11.0.0 netmask 255.255.0.0 gw 10.100.231.97 vlan1 >> /usr/local/sbin/post-boot
    echo route add -net 217.17.164.0 netmask 255.255.255.0 gw 10.100.231.97 dev vlan1 >> /usr/local/sbin/post-boot
    echo route add -net 188.94.52.0 netmask 255.255.255.0 gw 10.100.231.97 dev vlan1 >> /usr/local/sbin/post-boot
    Шаг.4
    echo "#!/bin/sh" >> /usr/local/sbin/post-firewall
    chmod +x /usr/local/sbin/post-firewall
    echo iptables -A INPUT -i vlan1 -m state --state NEW -j SECURITY >> /usr/local/sbin/post-firewall
    echo iptables -A FORWARD -i vlan1 -m state --state NEW -j SECURITY >> /usr/local/sbin/post-firewall
    echo iptables -t nat -A POSTROUTING -o vlan1 ! -s 10.100.231.102 -j MASQUERADE >> /usr/local/sbin/post-firewall
    echo iptables -t nat -A PREROUTING -d 10.100.231.102
    Шаг.5
    flashfs save
    flashfs commit
    flashfs enable
    reboot
    В итоге...а в итоге второй провайдер не работает. Надеюсь на вашу помощь. Help me
    Asus WL-500W
  12. #72
    Подскажите, как сделать и возможно ли такое вообще:
    Нужно на WAN вернуть влан локалки, но в тэгированом виде. в идеале и инет в тэге брать.
    Схема следующая:
    конфинг свича:
    Interface Ethernet1/2
     name TO_DVD2516
    Interface Ethernet1/3
     name TO_PLAYER
    Interface Ethernet1/4
     name TO_VOIP
    Interface Ethernet1/8
     name LINK_TO_RA1
     switchport mode trunk
     switchport trunk allowed vlan 1-2
    Interface Ethernet1/9
     name LINT_ISP_IS74
     switchport access vlan 2
  13. #73
    как работать с тегированным WAN
    Гуру подскажите можно ли сделать следующее:
    Есть локалка. На входе умный коммутатор, на нем локальный трафик с VID 1 untagged, а трафик от провайдера прокинут с входного порта на все внутренние с VID 2 как tagged.
    Роутером работает WL500W. Сейчас он делает это в паре со вторым умным коммутатором, все функции которого заключаются в "разтагивании" пакетов провайдера и передаче на WAN роутера.
    Возможно ли возложить эту функцию на роутер?
    Т.е. в идеале иметь один порт на роутере в качестве аплинка до умного коммутатора (например LAN1), на котором сидели бы чистый трафик локалки и помеченный провайдера и роутер работал бы по одному этому порту.
    Пробовал делать
    nvram set vlan0ports="0 1 2 3 5*"
    nvram set vlan1ports="0t 5"
    nvram set wan_ifnames=vlan1
    nvram set wan_ifname=vlan1
    nvram commit
    reboot
    локалка работает, а провайдер не виден
  14. #74
    Quote Originally Posted by ybny9f21 View Post
    Разобрался сам
    Помогло:
    nvram set vlan0ports="0 5*"
    nvram set vlan2ports="0t 5t"
    nvram set vlan2hwname=et0
    nvram set wan_ifnames=vlan2
    nvram set wan_ifname=vlan2
    nvram commit
    reboot
    Last Post: 28-07-2019, 19:41
  2. Подключение USB HDD для новичков
    Last Post: 26-03-2016, 08:33
  3. WL-320gE/550gE - подключение USB портов
    By Kirill in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 15-02-2014, 08:20
  4. Подключение USB принтера HP к WL-500gP
    By toto in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 08-05-2012, 21:09
  5. Подключение WL-500gP по PPTP
    By Pavel in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 13-11-2008, 11:25
