hi
I know that this topic has been talked through many many times, but...
I have a fixed and a wireless connection to my wl500g
My fix line samba speed is about 3,3 mbytes/s and it WAS the same for the wireless, but for some days it's below 600 kbytes/s. (tested in both within 5 minutes)
I just don't know the reason why.
I've made an iperf to the wireless line, and it says that it works perfectly:
"[root@asus root]$ iperf -c 192.168.1.45
Client connecting to 192.168.1.45, TCP port 5001
TCP window size: 16.0 KByte (default)
[ 5] local 192.168.1.1 port 1142 connected with 192.168.1.45 port 5001
[ 5] 0.0-10.0 sec 9.02 MBytes 7.56 Mbits/sec
[root@asus root]$
Already tried to turn off firewall and antivirus, but nothing changed.
Both are XP, with the same patch level.
Any ideas?![]()
