Results 1 to 5 of 5
Thread: samba speed on wireless
    Sep 2006
    Hungary
    hi
    I know that this topic has been talked through many many times, but...
    I have a fixed and a wireless connection to my wl500g
    My fix line samba speed is about 3,3 mbytes/s and it WAS the same for the wireless, but for some days it's below 600 kbytes/s. (tested in both within 5 minutes)
    I just don't know the reason why.
    I've made an iperf to the wireless line, and it says that it works perfectly:
    "[root@asus root]$ iperf -c 192.168.1.45
    Client connecting to 192.168.1.45, TCP port 5001
    TCP window size: 16.0 KByte (default)
    [ 5] local 192.168.1.1 port 1142 connected with 192.168.1.45 port 5001
    [ 5] 0.0-10.0 sec 9.02 MBytes 7.56 Mbits/sec
    [root@asus root]$
    Already tried to turn off firewall and antivirus, but nothing changed.
    Both are XP, with the same patch level.
    Any ideas?
    Jul 2007
    Austria
    I had the same problem several months ago - check out your neighbourhood, I bet at least one other is using the same channel or one in the near of yours.
    Check out a free channel - best is 1,6,11 because these don't interfere each other.
    Sep 2006
    Hungary
    Quote Originally Posted by newbiefan View Post
    thanx for the idea, but Cain says that it's not the case. It's only my network on channel 1 and there're two other on 6.
    = Cain's Wireless Scanner =
    BSSID: xxxxxxxx
    Last seen: 16/03/2008 - 20:20:44
    Vendor: ASUSTek COMPUTER INC.
    Signal: -50 dBm
    SSID: bbaccsi
    Enc: Yes
    Mode: Infrastructure
    Channel: 1 (2412000 Hz)
    Rates (Mbps): 1, 2, 5, 11, 18, 24, 36, 54,
    Packets:
    Unique WEP IVs:
    BSSID: 00146C216F02
    Vendor: Netgear Inc.
    Signal: -94 dBm
    SSID: 00146c216f02
    Enc: Yes
    Channel: 6 (2437000 Hz)
    Rates (Mbps): 1, 2, 5, 11, 6, 12, 24, 36,
    Packets:
    Unique WEP IVs:
    BSSID: 001B2F5DAE70
    Last seen: 16/03/2008 - 20:18:35
    Vendor: NETGEAR Inc.
    Signal: -94 dBm
    SSID: Chello
    Enc: Yes
    Packets:
    Unique WEP IVs:
    You need to set the asus to a FIXED channel.
    Try a few and see what works.
    Do you have security enabled on the asus? (not that someone is steeling bandwidth)
    Sep 2006
    Hungary
    Quote Originally Posted by avberk View Post
    Thx, I'll try putting it fixed on channel 1 in the evening.
    However, some facts are against the 'someone stealing bandwidth' theory:
    - ISP gives 5mbit/s connection so there should be huge to left for samba
    - iprerf did show more than 7mbyte/s, and my samba WAS 3,3 mbyte/s through wireless, a week before
    - on the desktop PC (with ethernet connection) the samba copy speed is still 3,3 mbyte/s
    - I'm checking the logs and sniffing for not usual packets often
    It's quite misterious for me...
  1. SAMBA 2 will not run
    By rj.2001 in forum WL-500g Q&A
    Last Post: 15-08-2007, 11:54
  2. drop in wireless speed despite good signal quality
    By HRUNTING in forum WL-700g Q&A
    Last Post: 25-01-2007, 01:59
  3. wl500g : wireless speed problems
    By silver32 in forum WL-500g Q&A
    Last Post: 13-03-2006, 01:48
  4. Replies: 0
    Last Post: 25-02-2006, 03:21
