Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Oleg's firmware and wl500gp v2
    Quote Originally Posted by againmoon View Post
    I have the same problem of lamocch, even if I use an other modem
    With V1 it worked....
    I would like to know if anybody tested a modem usb connection in V2.
    Just to know....
    Maybe power problems but in this http://koppel.cz/cdmawifi/english/
    lamocch said no change with powered usb hub
    My Hub has no AC power connecter, but this guy -tacothekid1- test with powered with the same results, maybe a fix came out soon:
    Quote Originally Posted by engy
    OK. I will try to fix this issue.
    Usb interfaces problems WL-500GP
    Does anybody tested v2 usb interfaces with usb modems
    I had the following problem with koppel.cz software.
    When I connect usb modems to my router, it does not recognize nothing, no vendor id , product id.
    I tried with modem onda HS600, nothing,
    SAMSUNG U700(HSDPA) , nothing
    Siemens P990 (UMTS), nothing
    WHen I connect hard disc no problem. I connected HDD IOMEGA 120 Giga no powered, ok.
    I connected 500 G LANCE HDD, external supply, ok
    I also connected an Iphone (it is not a modem) and it was recognized, even without external supply.
    I tried with powered usb hub, but nothing changed.
    Please engi, ask if I can help you...
    Thanks
  1. can't mount disk after switching to olegs firmware
    By bodvar in forum WL-500gP Q&A
    Last Post: 27-11-2009, 18:25
  2. Knöpfe am wl500gp mit olegs firmware
    By _H_o_L_E_ in forum German Discussion - Deutsch (DE)
    Last Post: 26-02-2008, 08:32
  3. Is Oleg's firmware lowering the Bandwidth?
    By piezomotor in forum WL-500gP Q&A
    Last Post: 22-01-2008, 11:35
  4. Replies: 3
    Last Post: 20-01-2008, 11:14
  5. i am decide to buy wl500gp and update firmware
    By alan168hk in forum WL-500gP Firmware Discussion
    Last Post: 01-11-2006, 02:00
