Originally Posted by
lly
А если так - то указания про что почитать, тебе давали (devfs, ftp, scp). Про /usr/local/.files ты тоже не дочитал, а снова ринулся в бой
Докладаю: работает, драйвер видит переходник и шара прекрасно заработала. Кусок лога:
Jan 1 02:00:04 kernel: Linux video capture interface: v1.00
Jan 1 02:00:04 kernel: SCSI subsystem driver Revision: 1.00
Jan 1 02:00:04 kernel: hub.c: connect-debounce failed, port 2 disabled
Jan 1 02:00:04 kernel: Initializing USB Mass Storage driver...
Jan 1 02:00:04 kernel: usb.c: registered new driver usb-storage
Jan 1 02:00:04 kernel: USB Mass Storage support registered.
Jan 1 02:00:04 kernel: vlan1: Setting MAC address to хх хх хх хх хх
Jan 1 02:00:05 udhcpc[90]: udhcpc (v0.9.9-pre) started
Jan 1 02:00:05 dhcp client: deconfig: lease is lost
Jan 1 02:00:05 udhcpc[90]: Lease of хх.х.х.хх obtained, lease time 604800
Jan 1 02:00:05 dhcp client: bound IP : хх.х.х.хх from yy.y.yy.yyy
Jan 1 02:00:05 kernel: hub.c: new USB device 01:03.0-2, assigned address 2
Jan 1 02:00:05 kernel: usb.c: USB device 2 (vend/prod 0x403/0x6001) is not claimed by any active driver.
Jan 1 02:00:05 pppd[101]: pppd 2.4.2 started by admin, uid 0
Jan 1 02:00:05 pppd[101]: Using interface ppp0
Jan 1 02:00:05 pppd[101]: local IP address yy.yy.yy.yy
Jan 1 02:00:05 pppd[101]: remote IP address yy.yyy.yyy.yyy
Jan 1 02:00:06 pppd[101]: Starting link
Jan 1 02:00:07 pppd[101]: Serial connection established.
Jan 1 02:00:07 pppd[101]: Connect: ppp0 <--> /dev/pts/0
Jan 1 02:00:07 kernel: usb.c: registered new driver serial
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for Generic
Jan 1 02:00:07 kernel: usbserial.c: USB Serial Driver core v1.4
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for FTDI SIO
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for FTDI 8U232AM Compatible
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for FTDI FT232BM Compatible
Jan 1 02:00:07 kernel: usbserial.c: FTDI FT232BM Compatible converter detected
Jan 1 02:00:07 kernel: usbserial.c: FTDI FT232BM Compatible converter now attached to ttyUSB0 (or usb/tts/0 for devfs)
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for USB-UIRT Infrared Receiver/Transmitter
Jan 1 02:00:07 kernel: usbserial.c: USB Serial support registered for Home-Electronics TIRA-1 IR Transceiver
Jan 1 02:00:07 kernel: ftdi_sio.c: v1.3.5:USB FTDI Serial Converters Driver
Jan 1 02:00:08 dnsmasq[69]: DHCPDISCOVER(br0) xx:xx:xx:xx:xx:xx
Jan 1 02:00:08 dnsmasq[69]: DHCPOFFER(br0) 192.168.1.209 xx:xx:xx:xx:xx:xx
Jan 1 02:00:08 dnsmasq[69]: DHCPREQUEST(br0) 192.168.1.209 xx:x:xx:xx:xx:xx
Jan 1 02:00:08 dnsmasq[69]: DHCPACK(br0) 192.168.1.209 xx:xx:xx:xx:xx:xx Sashunya
Jan 1 02:00:08 dnsmasq[69]: read /etc/hosts - 5 addresses
Jan 1 02:00:08 dnsmasq[69]: reading /tmp/resolv.conf
Jan 1 02:00:08 dnsmasq[69]: using nameserver 10.0.0.253#53
Jan 1 02:00:11 pppd[101]: Local IP address changed to xxx.xx.x.xx
Jan 1 02:00:11 pppd[101]: Remote IP address changed to xxx.xx.x.xxx
Jan 1 02:00:11 dnsmasq[69]: read /etc/hosts - 5 addresses
Jan 1 02:00:11 dnsmasq[69]: reading /tmp/resolv.conf
Jan 1 02:00:11 dnsmasq[69]: using nameserver 10.0.0.253#53
Jan 1 02:00:11 PPTP: connect to ISP
Я вижу что драйвер не сразу подхватился, но работает, черт побери. Далее при наличии инфы буду читать, я просто в этом полный чайник (хотя уже не совсем ). А вообще не помешают сцылочки на нужный материал, для человека не знающего линукс очень сложно.
Кстати, работает пока только час, но, похоже с переходником FTDI работает лучше (ни одного затыка, хотя не факт, ведь инет еще играет роль) нежели с PL2303.
