Thks v much to K Forge for the enhanced firmware. Finally, this white brick is beginning to live up to its promises. Need help from anybody who has successfully gotten MLMonkey & SanCho to work properly. After installation,
I have done the following as mentioned in this forum but am still unable to get downloading speeds more than >2KB per sec.
i. reconfigured BT Client port to 48888
ii. port forwarded, under NAT Setting - Virtual Server to port range & local port 488888, using local IP 192.168.1.1, for both TCP & UDP protocols
iii. use telnet to set iptables as stated in the forum
iptables -I FORWARD -p tcp --dport 48888 -j ACCEPT
iptables -t nat -I PREROUTING -i eth1 -p tcp --dport 48888 -j DNAT --to-destination 192.168.1.1
iv. inside Windows FireWall, opened up both incoming & outgoing rules for SaCho to have full access to TCP & UDP protocols
Pls advise what else I could do to get reasonable speeds. The torrents I selected has more than 1000 peers & 500 seeds. Thks v much.
rdgs
ray
