If you have hdd spin down enabled, then you would have to have S.M.A.R.T. disabled and so no health info is available.
I'm assuming you're using kfurge's custom firmware?
LK
I have some problem with my 700ge/ Disk manager in the web interface tells me that the health of my hd is unknown what do i have to do? may be its something wrong with it? Look at the pic
LK
I have standart firmware/ How can i chek disk when i start short test appears window that the test is started and then nothing else happens/ Besides after short test it tells me that everything is OK but when i try to start long test it says that that was an error of reading
Health details: Device: HDT722516DLAT80 Supports ATA Version 7
Drive supports S.M.A.R.T. and is enabled
Check S.M.A.R.T. Passed.
General Smart Values:
Off-line data collection status: (0x00) Offline data collection activity was
never started
Self-test execution status: ( 121) The previous self-test completed having
the read element of the test failed
Total time to complete off-line
data collection: (3385) Seconds
Capabilities: (0x5b)SMART EXECUTE OFF-LINE IMMEDIATE
Automatic timer ON/OFF support
Suspend Offline Collection upon new
command
Offline surface scan supported
Self-test supported
Smart Capablilities: (0x0003) Saves SMART data before entering
power-saving mode
Supports SMART auto save timer
Error logging capability: (0x01) Error logging supported
Short self-test routine
recommended polling time: ( 1) Minutes
Extended self-test routine
recommended polling time: ( 57) Minutes
Vendor Specific SMART Attributes with Thresholds:
Revision Number: 16
Attribute Flag Value Worst Threshold Raw Value
( 1)Raw Read Error Rate 0x000b 099 099 016 2
( 2)Throughput Performance 0x0005 100 100 050 0
( 3)Spin Up Time 0x0007 149 149 024 19792039
( 4)Start Stop Count 0x0012 100 100 000 49
( 5)Reallocated Sector Ct 0x0033 100 100 005 0
( 7)Seek Error Rate 0x000b 100 100 067 0
( 8)Seek Time Preformance 0x0005 100 100 020 0
( 9)Power On Hours 0x0012 100 100 000 22
( 10)Spin Retry Count 0x0013 100 100 060 0
( 12)Power Cycle Count 0x0032 100 100 000 49
(192)Power-Off Retract Count 0x0032 100 100 050 50
(193)Load Cycle Count 0x0012 100 100 050 50
(194)Temperature 0x0002 101 101 000 1638454
(196)Reallocated Event Count 0x0032 100 100 000 0
(197)Current Pending Sector 0x0022 100 100 000 1
(198)Offline Uncorrectable 0x0008 100 100 000 0
(199)UDMA CRC Error Count 0x000a 200 200 000 0
SMART Error Log:
SMART Error Logging Version: 1
No Errors Logged
Self Test Options: Run Short Test
Run Long Test
Notify Test Results
Up Up Up
