Page 5 of 12 FirstFirst ... 34567 ... LastLast
Results 61 to 75 of 174
Thread: Custom 1.0.7.8 firmware is ready to download
  1. #61
    Jan 2007
    The Netherlands
    Lightbulb How-to upgrade opt in the make
    I'm doing the update of this great firmware the difficult way. I want to update my opt directory, not to remove it.
    So I'm busy doing that and meanwhile I prepare sort of a howto for others.
    Of course, if one of you has it complete already, please overrule me.
    Marc
    O, BTW: I like to THANK mister Furge for his excellent job!
  2. #62
    Quote Originally Posted by mumsoft View Post
    Thank you Marc! I look forward to your how-to contributions.
    - K.C.
    P.S. I'm in the same boat you are. I have quite a substantial /opt on my own primary router that will be brought kicking and screaming to 1.0.7.8 soon.
  3. #63
    Will i lose files when reflashing.
    will i lose all my files on the box when i reflash/upgrading firmware?
  4. #64
    Quote Originally Posted by tuepen View Post
    99.9% of the time, no. There is always that .1% chance that something will go ker-plooie though. If you're the paranoid type, backup your goods.
  5. #65
    Jan 2007
    The Netherlands
    Not likely. But if you have a /shares/MYVOLUME1/opt folder and a running rc.local from your 1.0.4.6 KC Furge image, it is best to, BEFORE you do the update: mv /shares/MYVOLUME1/opt /shares/MYVOLUME1/opt_DO_NOT_LOAD
    If you get a message about opt being busy
    a) disable all own added software. Set # in front of such startups in rc.local, but at least leave the telnet stuff there unaltered.
    b) reboot
    c) mv /shares/MYVOLUME1/opt /shares/MYVOLUME1/opt_DO_NOT_LOAD (you need to have telnet running or this will not be possible)
    I have updated my Asus without this and had several problems with not starting up, resetting etc. I even had to reset to factory defaults once. I blame the old rc.local.
    But all my shares are untouched, music, pictures etc are not affected.
    So take care, and wait a while till I finish my how to
    Marc
  6. #66
    Quote Originally Posted by hweom View Post
    First of all, I want to thank kfurge for doing such a great job. Without this custom image, this router has only small part its powers.
    Now goes the question
    I've successfully installed the image and set up MLDonkey. However, MLDonkey seems to eat all available CPU time:
      PID  PPID USER     STAT   VSZ %MEM %CPU COMMAND
      541     1 root     R    40340  65%  93% /opt/bin/mlnet.lite -allowed_ips 127.
      582   580 root     S N  40340  65%   3% /opt/bin/mlnet.lite -allowed_ips 127.
      191     1 root     S     4880   8%   1% upnp -D -L br0 -W eth0
      588   587 admin    R     1792   3%   1% top
        4     1 root     RWN      0   0%   0% [ksoftirqd_CPU0]
        5     1 root     SW       0   0%   0% [kswapd]
      580   541 root     S    40340  65%   0% /opt/bin/mlnet.lite -allowed_ips 127.
    MLDonkey web interface loads for ages. It takes several minutes to fully load transfers page.
    Is it normal, or I have misconfigured something?
    i believe not, are you downloading files with many sources? or have you put files in your share folder and now its hashing? give more info's
  7. #67
    Jan 2008
    Italy
    Easy control for mldonkey
    Two question:
    1) Since mldonkey use a LOT of cpu resources would be very interesting having the possibility to start and stop it in a easy way. Stopping of course is only a matter of killing the core using Sancho, but restarting requires a telnet session and typing some annoying commands (not very comfortable).
    2) I have the ftp server accessible from wan and would be very interesting to me knowing who is connected at that time, possibly in real time. Is there the possibility? Could I manage the user's connections?
    Thanks in advance to anyone will help me.
    (sorry for my ignorance and rusty english, but EXPERTS exists to be hopefully helpful)
  8. #68
    Quote Originally Posted by elgatoz View Post
    I have ~10 files with >100 sources each.
    I have set up share a day ago, so I suppose hashing should be done by now. CPU usage is sill up to 100%
  9. #69
    Quote Originally Posted by marcolino View Post
    I wanted to ask the same thing! Or at least, be able to disable some accounts that have access to ftp?
    D.
  10. #70
    hmmm i think that is too much for the cpu
    you can play with loop_delay to save cpuload and try to reduce disk access cause i think this is still the bottleneck playing with diskbuffer etc..
    http://mldonkey.sourceforge.net/MemoryUsage maybe useful too
    but imo this will not help thats just too much,
    i started one big well seeded torrent ~40peers 500-700kb/s download= 80% cpuload, like to hear more mldonkey-experience on the wl700 here greetz
    edit: setting share_scan_intervall=0 try this too
  11. #71
    Quote Originally Posted by Henrikh View Post
    *NEVER MIND THIS. Bear with me, i have hangovers and have only slept for like 5 hours :-P*
    Your problem is that you have both the client_port and tracker_port set to the same value. The tracker_port defines what port MLDonkey will use if you want to run your own tracker, where the client_port is the port being used to download torrents. Just reset tracker_port to its default value (6881) and only change client_port.
    have you tried to open the file starting with the sudo command? (Eg. "sudo nano bittorrent.ini")? Or change the permissions (sudo chmod bittorrent.ini 777)?
    Thank you Henrikh!! this resolved my issue. I was in pain trying to get that fix and I only had 2 hrs of sleep that night.
    Now, I have second problem. I have wl700ge behind my Linksys WRT54G (192.168.3.1). wl700ge is getting a static IP addr. of 192.168.3.100. Meaning, I have wl700ge treated as a client behind my WRT54G. before I mess up the ports 2 days ago, I was able to HTTP access MLdonkey by typing in 192.168.3.100:4080. The first time I had an error that asked me to add my PC's ip address (192.168.3.109) into mldonkey's 'allowed_ips'. I did, and it worked.
    Now after i fixed the port issue, I can't access it anymore. i have even tried the 'nvram set kc_ssh_wan_access=Yes' still no go. I wonder what I did wrong? note, I can access WL700gE web Manager by just typing in 192.168.3.100 tho.. umm..
    So, simply, hope the above arn't too complicated. I wish to access mldonkey's webui from outside... it was possible before, but now can't. Any suggestions?
    thanks in advance.. and kfurge, keep up the great work! I appreciate what you offer to the community!
  12. #72
    Quote Originally Posted by monkey8 View Post
    Interesting. You shouldn't have had to do this since the entire internal subnet 192.168.3.x is configured for full access by the startup script.
    What do you mean by outside? So far everything you mentioned has been "inside". I.e. on the LAN interface 192.168.3.x. Is this what you can no longer access?
    Please log into the router via telnet or ssh and post the mldonkey startup output in /tmp/mldonkey.out.
    - K.C.
  13. #73
    Quote Originally Posted by kfurge View Post
    Something must have happened when the file got copied... The 42000 GID is indicative of an Asus made user. Maybe you didn't copy it as root? The firmware image has the UID:GID for all files set to 0:0.
    Fixing is easy with chgrp, though other sudo related files are probably also broken.
    - K.C.
    I have a problem same Neil
    Downloading http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz
    wget: missing URL
    Usage: wget [OPTION]... [URL]...
    Try `wget --help' for more options.
    An error ocurred, return value: 1.
    Collected errors:
    ipkg_download: ERROR: Command failed with return value 1: `wget    -q -P  http://ipkg.nslu2-linux.org/feeds/optware/oleg/cross/stable/Packages.gz'
    WARNING: Unable to remove temporary directory: : No such file or directory
    Sorry this is a dumb question and Im very newbie.
    I don't know how to chgrp. ?
    Could you give me more detail fro fix this problem ?
  14. #74
    - K.C.
    Thanks for the prompt reply, kfurge.
    mldonkey startup output in /tmp/mldonkey.out:
    2008/01/29 19:05:44 [cO] Starting MLDonkey 2.9.2 ...
    2008/01/29 19:05:44 [cO] Language EN, locale ASCII, ulimit for open files 1024
    2008/01/29 19:05:44 [cO] MLDonkey is working in /shares/MYVOLUME1/MYSHARE1/.mldonkey
    2008/01/29 19:05:44 [Gettext] Loading language resource mlnet_strings.EN_ASCII
    2008/01/29 19:05:44 [cO] loaded language resource file
    2008/01/29 19:05:44 [DNS] Resolving [WL700gE] ...
    2008/01/29 19:05:45 [DNS] Resolving [www.mldonkey.org] ...
    2008/01/29 19:05:45 [cO] Logging in /shares/MYVOLUME1/MYSHARE1/.mldonkey/mlnet.log
    2008/01/29 19:05:49 [dMain] Core started
    Here is my current connection:
    Linksys (WAN IP= Public addr., LAN IP = 192.168.3.1)
    +----- wl700ge (WAN IP= 192.168.3.100, LAN IP 192.168.1.1)
    | +------ System two (LAN IP = 192.168.1.100)
    +----- System One (LAN IP = 192.168.3.109)
    as you can see from the above diagram, from System two, I have no problem accessing mldonkey's http webui. However, I'm not able to from System One, which I was able to before. Any ideas?
    thx.
  15. #75
    What about connecting to the Mldonkey web interface (or via sancho) from the outside (WAN)? Is that possible?
  1. Installing Optware Packages on Asus Firmware 1.0.7.8
    By emailpr in forum WL-700g Firmware Discussion
    Last Post: 16-01-2008, 01:13
  2. wan to lan filter on default firmware 1.0.7.8?
    By nully in forum WL-700g Firmware Discussion
    Last Post: 10-11-2007, 23:36
  3. Custom Firmware v1.1.2.7
    Last Post: 11-12-2004, 12:26
