Hello
Which ver. of Transmission is working? Transmission 1.11+ (5633) has problems with autoseeding. Where can find previous versions? (.ipk)
Thanks
silvestre
you are upgrading ok.
Now I see the same problem as you. Looks like a bug in libtransmission. Will look at it ASAP.
Hello
Thanks
silvestre
Maybe the problem is just in .status files. Upload seems to work. Will see if upcoming release will solve this anyway. Otherwise solution will be found ASAP.
I'm afraid new ver. transmission_1.11+r5645-1_mipsel.ipk didn't solve the problem
After moving into "target":
"Apr 19 11:04:15 transmissiond[10301]: /opt/!share/torrent/work/sth.exe/.status - No such file or directory"
There is not any change in sth.resume file. I have to do it manually.
Thanks
silvestre
Edit:
Version transmission_1.11+r5651-1_mipsel.ipk is solving the problem with autoseeding
Thank You!
I've also experienced core dumps but then I've started over with fresh torrents and it looks it works. But the bug is still there. Let's hope that future versions will sovle this.
Maybe. Maybe not. Bug catching can be hard. There are some bug reports like http://trac.transmissionbt.com/ticket/884 and thrown away with "works for me" scenario. So if you are keen enough you can create debug version of transmission with
setCode:make electric-fence-stage
and disable stripping when package is made.Code:TRANSMISSION_CPPFLAGS=-g -O0 TRANSMISSION_LDFLAGS=-lefence -lpthread
When crash occurs you will find a coredump in $HOME/.config/transmission directory. Then just run
and typeCode:gdb /opt/bin/transmissiond core.PID
to unroll the stack.Code:where
If this is too deep you will need to
or so. Then if you do not understand the report to fix the bug for yourself, just post this stack in a similar or new ticket.Code:set heuristic-fence-post=30000
Anyway, latest release is underway.
With http://trac.nslu2-linux.org/optware/changeset/8221 transmission package also provides debug version. I've found possible bug in r5643 as shown in README.daemon.
Debug possibility varies from platform to platform. For oleg firmware buildroot package provides gdb.
I've downgraded the package too. Use -force-downgrade to get "what I think" stable version.
Strange bug/feature in Transmission daemon 1.11+ (5651), every 30 minutes the Transmission daemon is restarted. Checking files takes >30 minutes, so it's in a continous loop......
EdCode:Apr 26 00:30:08 transmissiond[28721]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 00:30:08 transmission_watchdog: Transmission daemon restarted! Apr 26 00:30:13 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB.torrent Apr 26 00:30:14 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB.torrent Apr 26 00:30:14 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB.torrent Apr 26 00:30:15 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/work/The_Bank_Job_(Dutch).4151182.TPB/The_Bank_Job_(Dutch).4151182.TPB.torrent Apr 26 00:30:17 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/target/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB.torrent.seeding Apr 26 00:30:19 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/target/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB.torrent.seeding Apr 26 00:30:21 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/target/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB.torrent.seeding Apr 26 00:30:23 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/target/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB.torrent.seeding Apr 26 00:30:24 transmissiond[28721]: Starting torrent /tmp/harddisk/torrent/target/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB.torrent.seeding Apr 26 01:00:09 transmissiond[28760]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 01:00:09 transmission_watchdog: Transmission daemon restarted! Apr 26 01:00:15 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB.torrent Apr 26 01:00:16 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB.torrent Apr 26 01:00:16 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB.torrent Apr 26 01:00:17 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/work/The_Bank_Job_(Dutch).4151182.TPB/The_Bank_Job_(Dutch).4151182.TPB.torrent Apr 26 01:00:19 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/target/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB.torrent.seeding Apr 26 01:00:21 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/target/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB.torrent.seeding Apr 26 01:00:23 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/target/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB.torrent.seeding Apr 26 01:00:25 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/target/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB.torrent.seeding Apr 26 01:00:26 transmissiond[28760]: Starting torrent /tmp/harddisk/torrent/target/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB.torrent.seeding Apr 26 01:30:09 transmissiond[29494]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 01:30:09 transmission_watchdog: Transmission daemon restarted! Apr 26 01:30:15 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB.torrent Apr 26 01:30:16 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB.torrent Apr 26 01:30:16 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB.torrent Apr 26 01:30:17 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/work/The_Bank_Job_(Dutch).4151182.TPB/The_Bank_Job_(Dutch).4151182.TPB.torrent Apr 26 01:30:19 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/target/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB.torrent.seeding Apr 26 01:30:21 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/target/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB.torrent.seeding Apr 26 01:30:23 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/target/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB.torrent.seeding Apr 26 01:30:25 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/target/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB.torrent.seeding Apr 26 01:30:25 transmissiond[29494]: Starting torrent /tmp/harddisk/torrent/target/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB.torrent.seeding Apr 26 02:30:09 transmissiond[30418]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 02:30:09 transmission_watchdog: Transmission daemon restarted! Apr 26 02:30:14 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB.torrent Apr 26 02:30:15 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB.torrent Apr 26 02:30:16 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB.torrent Apr 26 02:30:16 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/work/The_Bank_Job_(Dutch).4151182.TPB/The_Bank_Job_(Dutch).4151182.TPB.torrent Apr 26 02:30:18 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/target/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB.torrent.seeding Apr 26 02:30:21 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/target/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB.torrent.seeding Apr 26 02:30:23 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/target/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB.torrent.seeding Apr 26 02:30:25 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/target/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB.torrent.seeding Apr 26 02:30:26 transmissiond[30418]: Starting torrent /tmp/harddisk/torrent/target/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB.torrent.seeding Apr 26 03:00:09 transmissiond[30457]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 03:00:09 transmission_watchdog: Transmission daemon restarted! Apr 26 03:00:14 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB/BAND_OF_BROTHERS_Disc_1_-_BB4E.4154622.TPB.torrent Apr 26 03:00:15 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB/BAND_OF_BROTHERS_Disc_2_-_BB4E.4154624.TPB.torrent Apr 26 03:00:16 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/work/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB/BAND_OF_BROTHERS_Disc_3_-_BB4E.4154628.TPB.torrent Apr 26 03:00:17 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/work/The_Bank_Job_(Dutch).4151182.TPB/The_Bank_Job_(Dutch).4151182.TPB.torrent Apr 26 03:00:19 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/target/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB/Captivity_(2007)_ENG_DUTCH_SUB_by_nudaten.net.4140437.TPB.torrent.seeding Apr 26 03:00:21 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/target/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB/Het.Geheim.van.de.Kaasfabriek.DUTCH.4121063.TPB.torrent.seeding Apr 26 03:00:24 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/target/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB/Jochem_Myjer_-_Adehade.DUTCH.4139092.TPB.torrent.seeding Apr 26 03:00:27 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/target/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB/Pinnacle_Studio_9_MovieBox_Deluxe_DVD.3322069.TPB.torrent.seeding Apr 26 03:00:28 transmissiond[30457]: Starting torrent /tmp/harddisk/torrent/target/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB/The.Doors_[AC-3_5.1]_DVDrip_(Drama_1991_XviD).4096182.TPB.torrent.seeding Apr 26 04:00:09 transmissiond[30628]: Transmission daemon 1.11+ (5651) started - http://transmission.m0k.org/ at port 65534 Apr 26 04:00:09 transmission_watchdog: Transmission daemon restarted!
WL-500gP Oleg 1.9.2.7-10 WD500G
Ok,
Wil downgrade and buy some glasses
Ed
Dumb ass question?
How to downgrade Transmission?
Code:ipkg -force-downgrade.... .... .... ..... ???
Ed
