Hi folks, my first post here !
First of all : Oleg, thank you, and thank you all guys for you effort.
My brick is working almost perfectly with 1.9.2.7-8 firmware with samba2(vista ultimate ok!), uShare and Transmission.
I'm using a 120GB USB HD but something strange happen with Transmission.
It's quite fast downloading(reaches 300kB/s) but as soon as the the file has been completed it disapear! Both from work and target folder !
Does anybody experienced this problem?
Thanks for your help and have a merry christmas !
My transmission log from the cgi ..
here is my top:Code:Dec 18 12:29:56 transmission_watchdog: Transmission daemon restarted! Dec 18 12:29:56 transmissiond[946]: Transmission daemon 0.96+ (4182) started - http://transmission.m0k.org/ at port 65534 Dec 18 12:29:57 transmissiond[946]: Starting torrent /tmp/harddisk/torrent/work/xxxxx/xxxxxx.torrent Dec 18 12:29:57 transmissiond[946]: Starting torrent /tmp/harddisk/torrent/work/xxxxxx/xxxxxx.torrent Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/dae1dbaa1d93a09eb3d60f55184cb3fb411f44c1-cgi" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/dae1dbaa1d93a09eb3d60f55184cb3fb411f44c1" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/dae1dbaa1d93a09eb3d60f55184cb3fb411f44c1-cgi" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/dae1dbaa1d93a09eb3d60f55184cb3fb411f44c1" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/296e77600088a3bc716b2e1dc44ec4f490a7d968-cgi" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/296e77600088a3bc716b2e1dc44ec4f490a7d968" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/296e77600088a3bc716b2e1dc44ec4f490a7d968-cgi" No such file or directory Dec 18 12:30:28 transmissiond[946]: Couldn't get information for file "/tmp/harddisk/torrent/.transmission/cache/296e77600088a3bc716b2e1dc44ec4f490a7d968" No such file or directory
and my transmission.confCode:Mem: 29084K used, 1000K free, 0K shrd, 1532K buff, 17820K cached Load average: 2.17, 1.18, 0.92 (State: S=sleeping R=running, W=waiting) PID USER STATUS RSS PPID %CPU %MEM COMMAND 1269 admin R 448 1266 81.6 1.4 top 1265 admin S 692 102 27.2 2.3 dropbear 950 admin R 3176 949 0.0 10.5 transmissiond 946 admin S 3176 1 0.0 10.5 transmissiond 949 admin S 3176 946 0.0 10.5 transmissiond 1266 admin S 556 1265 0.0 1.8 sh 162 admin S 428 1 0.0 1.4 nmbd 1244 admin S 400 1 0.0 1.3 upnp 234 admin S 344 160 0.0 1.1 smbd 72 nobody S 252 1 0.0 0.8 dnsmasq 64 admin S 232 1 0.0 0.7 httpd 91 admin S 216 1 0.0 0.7 pppd 102 admin S 180 1 0.0 0.5 dropbear 93 admin S 176 1 0.0 0.5 watchdog 1 admin S 172 0 0.0 0.5 init 152 admin S 144 1 0.0 0.4 busybox_httpd 915 admin S 120 1 0.0 0.3 syslogd 74 admin S 120 1 0.0 0.3 nas 71 admin S 112 1 0.0 0.3 klogd 95 admin S 100 93 0.0 0.3 ntp 145 admin S 92 1 0.0 0.3 xinetd 59 admin S 76 1 0.0 0.2 telnetd 160 admin S 56 1 0.0 0.1 smbd 3 admin RWN 0 1 0.0 0.0 ksoftirqd_CPU0 107 admin SW 0 1 0.0 0.0 usb-storage-0 185 admin SW 0 1 0.0 0.0 kjournald 4 admin SW 0 1 0.0 0.0 kswapd 7 admin SW 0 1 0.0 0.0 mtdblockd 6 admin SW 0 1 0.0 0.0 kupdated 2 admin SW 0 1 0.0 0.0 keventd 5 admin SW 0 1 0.0 0.0 bdflush 108 admin SW 0 1 0.0 0.0 scsi_eh_0 124 admin SW 0 1 0.0 0.0 kjournald
Code:[admin@(none) /opt]$ cat /opt/etc/transmission.conf # Configuration # NOTE: no spaces around the = sign # the config will be sourced (eg. . transmission.conf) SOURCE=/tmp/harddisk/torrent/source WORK=/tmp/harddisk/torrent/work TARGET=/tmp/harddisk/torrent/target #MAILTO=torrent@somedomain.com #MAILFROM=torrent@somedomain.com MAILOPT="-smail.somedomain.com -f" USER=admin GROUP=root DATE_FORMAT="%d %h %H:%M" # Transmission daemon variables PIDFILE=/opt/var/run/transmission.pid ACTIVE=/tmp/harddisk/torrent/active-torrents.txt HOME=/tmp/harddisk/torrent WATCHDOG=300 LISTENING_PORT=65534 # set SPEED in kB/s or -1 for unlimited UPLOAD_SPEED=10 DOWNLOAD_SPEED=-1 #UPLOAD_SPEED=41 #DOWNLOAD_SPEED=180 # change SYSLOG from /tmp/syslog.log to SYSLOG=/opt/var/log/messages #Uncomment the following for UPNP NAT traversal #NAT_TRAVERSAL=--nat-traversal # Seed torrent after completition (YES or NO) AUTOSEED=YES # Enable removing of DONE non-seeding torrents in ${TARGET} directory FORCE_REMOVE=YES # If the following limit is reached watchdog will not enqueue new one MAX_ACTIVE_TORRENTS=10 # Creating graphical log of transfer with gnuplot # can be very site specific issue. See transmission.cgi # how this variables are used. GNUPLOT=/opt/bin/gnuplot GNUPLOT_COMMAND=${WORK}/transfer.gnuplot GNUPLOT_DATA=${WORK}/transfer.data GNUPLOT_OUTPUT=/opt/share/www/transfer.png HTTP_IMG_LOCATION=../transfer.png #TZ offset in seconds. Use +- sign. DST manually TIMEZONE_OFFSET=+3600 #Colors for command line. # comment out if not needed GREEN="\033[32;1m" #NC="\033[0m" #BACK_UP="\033[1K\033[0G" NORMAL="\033[0m" WARN="\033[33;1m" BAD="\033[31;1m" BOLD="\033[1m" GOOD="\033[32;1m"
