Results 16 to 30 of 40
Thread: Project WL-HDD and Weather Station (WS2300)
    Jun 2005
    Slovenia
    It should. Depending on your hardware for communication. Safe way is RS232 hardware mod.
    Feb 2005
    Germany - Frankfurt a.M.
    Thanks for replying.
    What is a RS232 hardware mod. ?
    Jun 2005
    Slovenia
    RS232 level converter using MAX3232 or similar chip that connects to internal header where RS232 serial signals are available along with power for level converter.
    Feb 2005
    Thanks for your info.
    Can somebody compile the program? (like described in the install-file)
    Oleo, can you make an ipkg package?
    Feb 2005
    Does anybody know, how to add a programm to ipkg??
    Jun 2005
    Slovenia
    Feb 2005
    Thumbs up
    Thank You SOOOO Much!!!
    But,
    how can i now add this to my wl500-gP?
    Just "ipkg install open2300" ???
    Jun 2005
    Slovenia
    yes. I recommend oleg feed.
    Thanks goes to Brian Zhou.
    Question Project WL-HDD and Weather Station (WS2300)
    Hello,
    i've a prject to use my WL-HDD with my Weather Station LacrossTechnologi WS2300.
    I need to know if that is possible with Oleg's firmware (or other) :
    - use a USB-RS232 adapter
    - use Perl for WS2300 linux script
    Anyone can help me. Is my first experience with alternate firmware for WL-HDD.
    I work on Windows XP on my computer.
    Nebuka
    With some search on forum i've already to function my USB to serial adapter (PL2303)
    But when i want to install the package open2300 (for the weather station) i've this message :
    mkdir: Cannot create directory `//opt/tmp/': Read-only file system
    I need to connect with root in console but what is the root password ?
    Nebuka
    Quote Originally Posted by nebuka View Post
    Nebuka
    Nebuka,
    this usually means you haven't mounted you file-system. see http://wl500g.info/showthread.php?t=10307
    Nov 2005
    Hello,
    Quote Originally Posted by mistraller View Post
    I run serial over tcp successfully with ser2net.
    Look at this topic.
    http://wl500g.info/showthread.php?t=4535
    On my pc I have a virtual comport software.
    look here:
    http://www.hw-group.com/products/hw_vsp/index_en.html
    This works for my Solar inverter readings.
    But now I want to put this readings in a RRD graph, but I don't know how I can create a script to write commands and read the serial output. Some examples run on perl, but use a module which is not included in the microperl package installed on my asus. Any idea?
    Does it work your system of Linux-Programm "ser2net" an the Windows-Programm for the "virtual-RS232"? Or is a hope?
    Thanks.
    Quote Originally Posted by Jeroen van Omme View Post
    Nebuka,
    Thanks Jeroen van Omme, i've install corectly the oleg firmware with your link.
    I've install the open2300 and correctly configure the USB to Serial adapter.
    But fetch2300 dosen't work fine, i've some line :
    pl2303.c: pl2303_read_int_callback - usb_submit_urb failed with result -22
    with dmesg.
    I've found on this site (NSLU2)
    the same probleme.
    But when I want to install the new driver i can't replace the original pl2303.o file by the new pl2303.o file. On WL-HDD the file pl2303.o is in read-only.
    How can replace the pl2303.o file ?
    Hello,
    nobody have a idea for my problem ?
    Anyone have been already use a WS2300 with a WL-HDD ?
    Thanks
    Nebuka
    Stribog - weather station software for WL500gP V2
    Hi there,
    if anyone here is interested in weather forecast look at www.stribog.net.
    Software is running from flashdisk and is able to present weather station data on internal ASUS web server.
    Mac
