Page 3 of 104 FirstFirst 123451353103 ... LastLast
Results 31 to 45 of 1550
Thread: Владельцам WL-520gc и WL-520gu
    попробовал перенести 192.168.0.1 из heart-beat server в default gateway - результат отрицательный
    Jan 1 00:00:09 pppd[77]: pppd 2.4.2 started by (unknown), uid 0
    Jan 1 00:00:09 pppd[77]: Serial connection established.
    Jan 1 00:00:09 pppd[77]: Using interface ppp0
    Jan 1 00:00:09 pppd[77]: Connect: ppp0 -> /dev/pts/0
    Jan 1 00:00:12 pppd[77]: Modem hangup
    Jan 1 00:00:12 pppd[77]: Connection terminated.
    Jan 1 00:00:43 pppd[77]: Serial connection established.
    Jan 1 00:00:43 pppd[77]: Using interface ppp0
    Jan 1 00:00:43 pppd[77]: Connect: ppp0 -> /dev/pts/0
    Jan 1 00:01:07 pppd[77]: Modem hangup
    Jan 1 00:01:07 pppd[77]: Connection terminated.
    Jan 1 00:01:37 pppd[77]: Serial connection established.
    Jan 1 00:01:37 pppd[77]: Using interface ppp0
    Jan 1 00:01:37 pppd[77]: Connect: ppp0 -> /dev/pts/0
    Jan 1 00:01:37 pppd[77]: Modem hangup
    Jan 1 00:01:37 pppd[77]: Connection terminated.
    Jan 1 00:02:08 pppd[77]: Serial connection established.
    Jan 1 00:02:08 pppd[77]: Using interface ppp0
    Jan 1 00:02:08 pppd[77]: Connect: ppp0 -> /dev/pts/0
    Jan 1 00:02:39 pppd[77]: LCP: timeout sending Config-Requests
    Jan 1 00:02:39 pppd[77]: Connection terminated.
    Jan 1 00:03:09 pppd[77]: Serial connection established.
    Jan 1 00:03:09 pppd[77]: Using interface ppp0
    Jan 1 00:03:09 pppd[77]: Connect: ppp0 -> /dev/pts/1
    Jan 1 00:03:40 pppd[77]: LCP: timeout sending Config-Requests
    Jan 1 00:03:40 pppd[77]: Connection terminated.
    вывод ipconfig /all при соединенном vpn без роутера, напрямую
    Windows IP Configuration
    Host Name . . . . . . . . . . . . : lchost
    Primary Dns Suffix . . . . . . . :
    Node Type . . . . . . . . . . . . : Unknown
    IP Routing Enabled. . . . . . . . : Yes
    WINS Proxy Enabled. . . . . . . . : No
    Ethernet adapter Internet Connection:
    Connection-specific DNS Suffix . :
    Description . . . . . . . . . . . : Realtek RTL8139 Family PCI Fast Ethernet NIC
    Physical Address. . . . . . . . . : 00-50-22-91-DD-5A
    Dhcp Enabled. . . . . . . . . . . : No
    IP Address. . . . . . . . . . . . : 192.168.5.73
    Subnet Mask . . . . . . . . . . . : 255.255.0.0
    Default Gateway . . . . . . . . . :
    DNS Servers . . . . . . . . . . . : 192.168.0.1
    PPP adapter inet:
    Description . . . . . . . . . . . : WAN (PPP/SLIP) Interface
    Physical Address. . . . . . . . . : 00-53-45-00-00-00
    IP Address. . . . . . . . . . . . : 172.16.5.73
    Subnet Mask . . . . . . . . . . . : 255.255.255.255
    Default Gateway . . . . . . . . . : 172.16.5.73
    Kharkov
    Oleg
    В настройках маршруты можно прописывать для трех сетей LAN, WAN и MAN.
    Маршруты которые предлагает прописать провайдер я прописал для WAN - верно ли это?
    Например маршрут для одной из сетей , которая пропадает:
    На роутере: 10.0.0.0__ 255.0.0.0__192.168.186.1 (IP провайдер дает постоянный - 192.168.186.204);
    На компе : 10.0.0.0__ 255.0.0.0__192.168.186.204
    Поясните еще, пожалуйста , в чем различие MAN и WAN в данном случае.
    Спасибо.
    Оставьте его там, а также напишите что на Status | Routing Table
    в Status & Log/Routing Table:
    192.169.1.0 * 255.255.255.0 U 0 0 0 LAN
    192.168.0.0 * 255.255.0.0 U 0 0 0 WAN
    вручную маршруты не прописывал
    в Status & Log/DHCP Leases:
    Host Name Mac Address IP Address Lease
    lchost 00:50:22:91D:5A 192.169.1.2 86194 secs
    в Status & Log/Status:
    картинка во вложении (disconnected)
    если сделать logout, то пишет при последующем входе:
    Internet Connection Status
    Type PPTP
    Status: Disconnected
    Reason No response from ISP.
    я не понял, оставить 192.168.0.1 в gateway или в vpn-сервер?
    Kharkov
    Вобщем прочитал "Часто задаваемые вопросы" . прописал маршруты только теперь для MAN все работает. Спасибо Oleg.
    Теперь только статистики не хватает.
    Quote Originally Posted by igr_ok View Post
    gateway.
    Я сделал новую прошивку с расширенным логом для pptp:
    http://oleg.wl500g.info/asus/WL520gu_0.0.0.5_EN.trx
    Давайте её лог и routing table.
    Просьба ко всем, у кого WL-520gC - проверьте точность хода часов на странице статуса: засечь время и через минуту глянуть ещё раз на показания. Они либо идут правильно, либо отстают на 10 секунд в минуту. Хотя вряд ли.
    залил 0.0.0.5
    вот такой получился лог:
    Jan 1 00:00:09 pptp[84]: The synchronous pptp option is NOT activated
    Jan 1 00:00:09 pptp[84]: route_add: no route to host
    Jan 1 00:00:40 pppd[77]: LCP: timeout sending Config-Requests
    Jan 1 00:00:40 pppd[77]: Connection terminated.
    Jan 1 00:01:11 pptp[107]: The synchronous pptp option is NOT activated
    Jan 1 00:01:11 pptp[107]: route_add: no route to host
    Jan 1 00:01:11 pppd[77]: Serial connection established.
    Jan 1 00:01:11 pppd[77]: Using interface ppp0
    Jan 1 00:01:11 pppd[77]: Connect: ppp0 -> /dev/pts/1
    Jan 1 00:01:42 pppd[77]: LCP: timeout sending Config-Requests
    Jan 1 00:01:42 pppd[77]: Connection terminated.
    Jan 1 00:01:57 pptp[110]: connect: No route to host
    Jan 1 00:01:58 pptp[110]: Could not open control connection to 192.168.0.1
    Jan 1 00:01:58 pptp[107]: Call manager exited with error 256
    Jan 1 00:02:12 pppd[77]: Serial connection established.
    Jan 1 00:02:12 pppd[77]: Using interface ppp0
    Jan 1 00:02:12 pppd[77]: Connect: ppp0 -> /dev/pts/1
    Jan 1 00:02:12 pptp[126]: The synchronous pptp option is NOT activated
    Jan 1 00:02:12 pptp[126]: route_add: no route to host
    Jan 1 00:02:43 pppd[77]: LCP: timeout sending Config-Requests
    Jan 1 00:02:43 pppd[77]: Connection terminated.
    и routing table
    Вы уверены в том, что
    1) адрес впн сервера 192.168.0.1?
    2) не нужно клонировать мак адрес сетевой карты Вашего пк?
    1) в настройках от провайдера указан пустой default gateway и адрес vpn-сервера - ppp.k-net.ru
    при установленном vpn-соединении без роутера я делаю ping ppp.k-net.ru и вижу, что пингуется 192.168.0.1
    кроме того, если я в настройках vpn-соединения опять же при соединении напрямую, без роутера заменяю ppp.k-net.ru на 192.168.0.1, то соединяется как обычно
    из этого всего я делаю вывод, что адрес vpn-сервера: 192.168.0.1
    2) насчет мак-адреса - провайдер его не требует, так как я уже пробовал успешно устанавливать vpn с другого компьютера по беспроводной сети, соответственно, с другим мак-адресом; vpn инициировалось при этом самим компьютером (не роутером)
    наткнулся вот на это
    http://wiki.archlinux.org/index.php/...ith_pptpclient
    Firewall isn't configured correctly
    If this is the case you should see logs from your firewall blocking things from your ip to my.vpn.server, but in case it helps, here is what it looks like from the pppd logs.
    When the firewall is blocking things
    pppd[25387]: pppd 2.4.4 started by root, uid 0
    pppd[25387]: Using interface ppp0
    pppd[25387]: Connect: ppp0 <--> /dev/pts/7
    pptp[25388]: anon log[mainptp.c:276]: The synchronous pptp option is NOT activated
    pppd[25387]: LCP: timeout sending Config-Requests
    pppd[25387]: Connection terminated.
    pppd[25387]: Modem hangup
    pppd[25387]: Exit.
    When the firewall is rejecting things
    pppd[24971]: pppd 2.4.4 started by root, uid 0
    pppd[24971]: Using interface ppp0
    pppd[24971]: Connect: ppp0 <--> /dev/pts/7
    pptp[24972]: anon log[mainptp.c:276]: The synchronous pptp option is NOT activated
    pptp[24974]: anon warn[open_inetsockptp_callmgr.c:326]: connect: Connection refused
    pptp[24974]: anon fatal[callmgr_mainptp_callmgr.c:124]: Could not open control connection to 206.169.229.172
    pptp[24972]: anon fatal[open_callmgrptp.c:439]: Call manager exited with error 256
    pppd[24971]: Modem hangup
    pppd[24971]: Connection terminated.
    pppd[24971]: Exit.
    логи уж очень на мои похожи
    это может как-то помочь?
    Да нет, с фаерволом всё хорошо. Да я и проверил практически вашу конфигурацию, работает...
    Роутеру адрес vpn сервера можно, да и нужно, задавать имя сервера, а не ip. Вписывать в поле Heart-Beat.
    Посмотреть фаервол можно на скрытой странице:
    iptables -L -vn
    Вот что ещё попробуйте: Поставьте конфигурацию Static IP. Перегрузите, попробуйте поднять vpn с ПК. И из cmd.exe попингуйте до этого 192.168.0.1.
    Nov 2007
    Moscow
    уже ответил в другой теме. у меня на gc отстают
    Серийник скажите, пожалуйста.
  1. "Обвязка" 3G и CDMA на прошивке энтузиастов
    By Vitaly_k in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 25-01-2013, 12:19
  2. Настройка ASUS WL-520gU
    By sadman in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 04-01-2012, 13:42
  3. Загрузка с USB flash на устройствах 2Mb flash
    By lightix in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 15-04-2011, 11:26
  4. объединение asus 500gp и asus 520gc
    By shi in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 12-04-2009, 11:17
