the keyword here is ntlmaps on client side with port-forwarding on the server side
it seems there are 2 problems to be solved...
1st:
user_agent = (null)
debug_level = 2
tunnel_in_connect: HTTP error 502
http_error_to_errno: HTTP error -502
couldn't open tunnel: Input/Output error
exit with status = 1
2nd:
seems that prerouting doesn't work as it should on the router, because entering the address in my browser brings the admin page of the router...
and maybe the 1st problem is even because of the second?...
could please anyone help how should I tell the router to accept incoming 80 port tcp connections and forward them directly to 8080 if not in the way I described above in one of my posts?
(please forgive my lameness )
