Results 1 to 8 of 8
Thread: MOVED: problem w/ KYOCERA PRINTER :(
    Unhappy problem w/ KYOCERA PRINTER :(
    hi all,
    hope someone can shed some light on this problem i have...
    bought wl-500g a few days ago... setting up was no problem.. upgraded the firmware to 1.8.1.9 (or something) and reset the machine (btw, heard from someone who read that to reset you have to press and hold the reset button for 5 seconds?? can someone confirm this?). and anyway... wireless is now good... i can get it to work and run at good speed, too.
    but my printer KYOCERA MITA FS-1010 still won't print... (i know, i am not sure why my sister got this printer, either). i read that you need the "remote port" when you install but i couldn't find that when i tried the printer wizard, only saw "standard tcp/ip port" or "local port". am i supposed to have that "remote port" thingy to run? a little confused...
    but yeah anyway after 3 days still no luck in getting it to print... kept havign error, despite that the machine detects it. also tried all sorts of drivers from the official kyocera website. no luck.... plz help
    thanks to anyone who can provide a lead or tip...
    Apr 2004
    Netherlands
    Please read the FAQ and forum rules. Every question you ask here has been answered before. You also post in the wrong forum (Firmware Releases), the right place is Question and Answers.
    Apr 2004
    frankfurt
    you are running the custom fw?
    if so, you have to set up an tcp connection to your printer in raw mode. thats it.
    i run the kyocera fs-680 with the wl500g and its running fine.
    Athlon XP 2200+ runnig on ECS K7S5A
    512 MB DDR
    160 GB Samsung
    Ati Radeon 9500
    System running under Yoper.v2
    Router: WL500g
    oops!
    sorry for posting in the wrong forum.. my apologies.
    question though - what did u mean by installing in "raw" mode? i can see that the printer shows up in the "device discovery" so it does recognize... what do i need to do to change it to "raw"? plz clarify. thanks.
    Nov 2003
    Eindhoven
    http://wl500g.dyndns.org/printing/
    read that page please
    procedure is almost the same for windows XP, although some screens differ a bit
    thanks
    thanks antiloop for your reply.
    i was just gonna post a thank-you note as i was going thru some old threads and found the same link as what u posted above. will try that tonight and hope it'll work!
    Apr 2004
    Netherlands
    Yes, yes, the search button is a powerful tool
    kyocera FS800 it works
    I have a kyocera FS800 connected on the // port of my WL500g and it works fine. I think that i have the same firmware that yours.
    I added a TCP/IP port and configure it on LPR protocole.
    a+
  1. Kyocera FS 1900
    By schmidt_as in forum WL-500g Q&A
    Last Post: 29-09-2005, 14:47
  2. [MOVED]Problem to enable Afterburner
    By maxx in forum WL-500g Q&A
    Last Post: 04-03-2005, 20:22
  3. printer problem solved
    By Kronos in forum WL-500g Q&A
    Last Post: 15-11-2004, 22:30
  4. Printer sharing problem
    By Fenni in forum WL-500g Q&A
    Last Post: 01-11-2004, 01:42
