writing a script here, but I have some problems.
the script has a loop where it scans directories in a dir.
Works fine, only problem is that when the dir has a space in the name I can't 'cd' to it within the .sh script.
I've tried various things, but I haven't managed to fix this.
Here goes:
(I've cut the part of the script where the error occurs.)
I have this dir: '/mnt/usenet_temp'
It contains 2 dirs: '2 2' & '3 3' (which contain rar packages, but that's not the issue here)
sSource='/mnt/usenet_temp'
# set working dir to the source dir
cd $sSource
# get the contents of the source dir in to a variable
# -p is used to append a / to the contents after each dir.
# this is for easier cutting
sSourceDirContents=$(dir -p)
# because sSourceDirContents contains more than 1 dir, only
# cut the first dir into variable sDir
sDir=`echo $sSourceDirContents | cut -d / -f 1`
# now I let the contents display to see what I've got
# contents would display: /mnt/usenet_temp/2\ 2
# if I 'cd' this manually I get to the dir
# this script can't 'cd' to it. command gets cut of after \
echo $sSource/$sDir
cd $sSource/$sDir
echo $(pwd)
# If I let this script do a 'static' 'cd' instead of a dynamic such as above
# it works !! I end up in the correct dir.
echo /mnt/usenet_temp/3\ 3
cd /mnt/usenet_temp/3\ 3
echo $(pwd)
As you can see I've put some comments in there which are normally not there.
First I build a string dynamically and try to use it to 'cd' to a dir, which does not work, while when I copy the output of this dynamic string and use that to 'cd' it works.
Also when I use a static 'cd' command in the script, it goes to the right dir.
does anybody have an solution how to dynamically 'cd' to a dir which contains a 'space' character ?
Thanks a lot !
