Hi, there
Here I am a couple of days later to continue the monologue.
But hey maybe it will help somebody. :-)
1.
First fucking big problem is that I can not add comment to the torrent. Oh this is real fucking big problem because I am a member of many closed torrent portals and by adding comment to the torrents I was able to see who belongs to who and I was able to keep manageable my stuff.
Well I installed on my PC the Windows Remote UI.
From here:
http://users.aber.ac.uk/anf6/projects/transmission/
And that UI shows the trackers and I can sort them there.
Visually I can keep track of them by the tracker.
How ever there is no possibility of the comment which is still bad.
An other thing, for me the Windows Remote UI did not worked and for this I needed to download the source and to correct it and recompile it.
I rewrote the following function:
private void Form1_Resize(object sender, EventArgs e)
if (Program.form != null)
if (Program.form.NotifyIcon.Visible && FormWindowState.Minimized == this.WindowState)
this.Hide();
2.
Second big fucking problem is that transmission 1.22 put the torrents in separate directory's.
For example it put them in a directory of the name of the torrent file.
Now this shit puts them in a directory unleashed mode.
This is bad because the old way I was able to manage the files much better.
3.
Third fucking big problem is that of putting the files into one directory the files will be open to abuse.
I do not know what would happen if you have two torrents with one readme.txt in the root.
Please somebody explain this to me.
Still a problem.
4.
It takes to me quite long time to upgrade because of the directory problems.
Well yeah this was a pain + the recheck.
5.
I can not see the syslog, log. (Log button missing)
Still looking for a solution.
6.
I can not get info about the torrent regarding what type
of files contains. (Info button missing)
This was solved by the Windows Remote UI.
You can see the details here.
7.
About button also missing.
8.
There is no fucking Fetch option.
Still a problem.
9.
During download does not shows to how many pears I am uploading.
Does not show the ratio in this stage.
Well on the Clutch you can see it in the Info panel.
Windows Remote UI also shows it.
And there is a 10 problem:
I can not limit the number of torrents only the upload/download speed.
