Page 7 of 7 FirstFirst ... 567
Results 91 to 98 of 98
Thread: Web gui for ctorrent - YODCTCS
  1. #91
    Hi.
    Just tested with Debian and it compiled correctly. It's a Ubuntu problem as it doesn't compile with any compiler there.
    Tested the dctcs compiled in Debian, but doesn't work! Complains in my wl600g with the message: ./dctcs: can't resolve symbol 'bzero'
    Mike
  2. #92
    I think you did not crosscompiled it. You need your firmware toolchain's gcc (and libs of course) to cross compile on pc for the wl600 target.
  3. #93
    Quote Originally Posted by dske View Post
    I've cross compiled it but I think it's a clibc problem. I have 0.9.27 on the router and maybe dctcs needs a better one like 0.9.28 or 0.9.29 but if I try that, it blows the compilation of asus firmware.
    Mike
  4. #94
    i compiled the oleg fw version with uclibc 0.9.19 and bzero is a legacy function in posix 2001.
    i still belive if you can compile it with bzero you should be able to use it with the correct librarys. (on my router i am using kamikaze so i can not test dctcs on other fws)
    You can try replace bzero with memset:
    #define bzero(x, n) memset(x, 0, n);
    (you can add the above line in common.h)
  5. #95
    Hi all!
    A small bugfix release:
    # Version 0.7.2 - 15/02/2009
    * bugfix: the wget details display is correct even the file size is unknown
    * recompiled with GWT 1.5.3
    * new option: ctorrent-complete command to be run after downloading finished
    * modified upload/download limit calculation after inactivity
    * packages for Whiterussian will not be built anymore
  6. #96
    Hi, i've installed dctcs_0.7.2-2-oleg_mipsel.ipk on Azbox (see http://www.satpimps.com/showthread.php?t=113468) and it works great!!!
    Many Thanks!!!
    I've found a small bug in the upload/download limit calculation: download limit
    is calculated with the value used for upload limit; checking the code in file client.c at line 431:
    cdl = cdl == 0 && ulimit != 0 ? ulimit * 1024 / numclients : cdl;
    instead of
    cdl = cdl == 0 && dlimit != 0 ? dlimit * 1024 / numclients : cdl;
    Sorry I can't compile the package cause i dont know how to prepare the required environment to build...
    Please, can you do something?
    Thanks in advance
    pppppp
    Hi all!
  7. #97
    yes i can do something
    even better i did.
    you can download the corrected version
    http://sites.google.com/site/yodctcs...attredirects=0
  8. #98
    even better i did.
    wow so fast!!
    thank you very much!
  1. Which web cameras are supported?
    By punhal in forum WL-500w Q&A
    Last Post: 05-05-2009, 11:51
  2. Web на 80 порту работает, а на других нет.
    By neyva in forum Russian Discussion - РУССКИЙ (RU)
    Last Post: 16-10-2007, 01:25
  3. best torrent client with web gui
    By amkrisis in forum WL-500gP Q&A
    Last Post: 01-06-2007, 09:12
  4. web interface loads only occasionally during boot
    Last Post: 18-10-2004, 10:48
