Hi bado,
You really have to get your feet wet on the linux front, I am currently working on the ASUS wl-700 with KC custom firmware and I am really pleased. I am only new to Linux so it does take time and plenty of mistakes to get the system as you want.
For help on learning Linux and the commands and what they mean check out
http://www.computerhope.com/.
Load up KC's custom Firmware
http://home.comcast.net/~kfurge/wl700ge.html
and have a go. before you complete the flashing check out the forum for tips on "how to make a better system" it's Step 5 of the above link. It caused me about 4 days of work arounds to get it finally into a state of working correctly.
On 1,2,3 cannot help not my area of interest.
4. Itunes.
You can use Mt-daapd to host Itunes, haven't completed this as yet, currently working on torrent and media server, myself. anyway, there is plenty of information on this in the forum
http://www.nslu2-linux.org/wiki/Optw...slung.Mt-daapd
5. torrent
http://www.wl500g.info/showthread.php?t=10390
http://www.wl500g.info/showthread.php?t=10041
You could try transmission which has been used on the 500 by Oleo.
You can also check out
http://www.nslu2-linux.org/wiki/Optware/Transmission
Best of luck, there is a great team here willing to help, but you have to roll up the sleeves and give your learning back so we can all learn and make better systems.
