Results 1 to 4 of 4
Thread: Has anyone got Mediatomb running
    Hello
    I'm a happy user of Oleg's firmware. I'm trying to get upnp support for my ps3. Twonky does not support mp4 files in their asus build (their PC build works fine...) so I have turned my attention to Mediatomb. I have installed it using ipkg but when I try to launch it I get the following log entries:
    [admin@WL500gp .mediatomb]$ mediatomb
    MediaTomb UPnP Server version 0.10.0 - http://mediatomb.cc/
    Copyright 2005-2007 Gena Batsyan, Sergey Bostandzhyan, Leonhard Wimmer.
    MediaTomb is free software, covered by the GNU General Public License version 2
    2007-10-03 17:43:42    INFO: Loading configuration from: /usr/local/root/.mediatomb/config.xml
    2007-10-03 17:43:42    INFO: Checking configuration...
    2007-10-03 17:43:42    INFO: Config: option not found: /server/servedir using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /server/ui/attribute::poll-when-idle using default value: no
    2007-10-03 17:43:42    INFO: Config: option not found: /server/ui/attribute::poll-interval using default value: 2
    2007-10-03 17:43:42    INFO: Config: option not found: /server/ui/items-per-page/attribute::default using default value: 25
    2007-10-03 17:43:42    INFO: Config: option not found: /import/filesystem-charset using default value: ASCII
    2007-10-03 17:43:42    INFO: Setting filesystem import charset to ASCII
    2007-10-03 17:43:42    INFO: Config: option not found: /import/metadata-charset using default value: ASCII
    2007-10-03 17:43:42    INFO: Setting metadata import charset to ASCII
    2007-10-03 17:43:42    INFO: Config: option not found: /import/playlist-charset using default value: ASCII
    2007-10-03 17:43:42    INFO: Setting playlist charset to ASCII
    2007-10-03 17:43:42    INFO: Config: option not found: /server/pc-directory/attribute::upnp-hide using default value: no
    2007-10-03 17:43:42    INFO: Config: option not found: /server/retries-on-timeout using default value: 0
    2007-10-03 17:43:42    INFO: Config: option not found: /server/interface using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /server/ip using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /server/bookmark using default value: mediatomb.html
    2007-10-03 17:43:42    INFO: Config: option not found: /server/modelName using default value: MediaTomb
    2007-10-03 17:43:42    INFO: Config: option not found: /server/modelDescription using default value: Free UPnP AV MediaServer, GNU GPL
    2007-10-03 17:43:42    INFO: Config: option not found: /server/modelNumber using default value: 0.10.0
    2007-10-03 17:43:42    INFO: Config: option not found: /server/serialNumber using default value: 1
    2007-10-03 17:43:42    INFO: Config: option not found: /server/manufacturerURL using default value: http://mediatomb.cc/
    2007-10-03 17:43:42    INFO: Config: option not found: /server/presentationURL using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /server/presentationURL/attribute::append-to using default value: none
    2007-10-03 17:43:42    INFO: Config: option not found: /server/upnp-string-limit using default value: -1
    2007-10-03 17:43:42    INFO: Config: option not found: /import/scripting/playlist-script/attribute::create-link using default value: yes
    2007-10-03 17:43:42    INFO: Config: option not found: /server/port using default value: 0
    2007-10-03 17:43:42    INFO: Config: option not found: /server/alive using default value: 180
    2007-10-03 17:43:42    INFO: Config: option not found: /import/autoscan using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /import/library-options/libexif/auxdata using default value:
    2007-10-03 17:43:42    INFO: Config: option not found: /import/magic-file using default value:
    2007-10-03 17:43:42    INFO: Configuration check succeeded.
    Now it just hangs. Has anyone had more success than me?
    Regards
    Maybe its up and running?
    When you invoke this cmd, can you connect with ps3? If yes, start the cmd and append a & at the end so that the task will be run in background!
    "mediatomb &"
    Stopping it would be "killall mediatomb"
    Jun 2005
    Slovenia
    As far as i know there is no posibility to run mediatomb unless we enable LJSJ for exception handling. I've done this in some unstable feed of the my toolchain but that change didn'get into trunk as it requires that all packages be rebuilded and reinstalled at users.
    See http://trac.nslu2-linux.org/optware/...clibc-unstable
    If there will be enough calls for that I might push this into trunk.
    Mar 2007
    Olari, Finland
    I hope to get Mediatomb to work some day.
    if there is any chance to get it working Iwould be very greatfull.
    Twonky doesn´t support all needs
  1. Mediatomb
    By avberk in forum WL-500g Q&A
    Last Post: 23-06-2011, 06:44
  2. Running the WL700gE at 300MHz
    By kfurge in forum WL-700g Tutorials
    Last Post: 10-02-2009, 03:10
  3. Mysql faster while running on the router?
    By Rykaerdoe in forum WL-500gP Q&A
    Last Post: 10-07-2007, 18:27
