firmware version?
I run into the following problem:
WindowsXP: I copy one file from a local drive to a shared drive. Now the shared drive is show to me in the explorer with a timestamp which is 1h later! Is I check the date/time on the Asus it has the same timestamp as my local drive.
Windows2000: Same procedure. Now the shared drive has an identical timestamp. But if I am looking on the Asus, the time is 1h less than displayed in the windows browser.
/etc/TZ: "MEZ+1MESZ"
What could be wrong (timezone/daylight saving)?
Thx
Andreas
firmware version?
It seems to me you have different timezones configured on the Windows boxes.
Most likely it's a SAMBA / LINUX configuration issue. Check out this SAMBA faq for some background info:
http://www.ifsi.rm.cnr.it/italy/Samba/sambafaq-3.html (scroll to "3.6")
Brubber
WL-500g, WL-138g, WL-160g
Had a same problem. Seems our-old version Samba has problem handling summer time. I solved this by setting TZ enviroment variable to UTC when invoking Samba in post-boot. Like this:
This solved things during the summer time and works still even now, when time is back the "winter time" .Code:TZ=GMT-0 /usr/sbin/nmbd -D TZ=GMT-0 /usr/sbin/smbd -D
Edit: My "normal" timezone is MEZ-1MESZ
Starting with yesterday (daylight change) everthing works well again. Hmm. I think the problem will come again next year. But it has definetly something to do with the daylight save. But I will keep all the answers in my mind.
Thx to all ... Andi
