Well, I've compiled hdparm (linked statically).
Somebody should try it and post output here.
hdparam of courseOriginally Posted by Antiloop
To be serious, I don't know. But because hdparam can do it on a regular Linux box, it probably can be set beforehand as well. I don't know enough of Linux to tell you where to do it.
Edit: Ah, Oleg allready produced hdparam. Jeez you're working fast *thumbs-up-smiley*
I thought these CPU's had hardware accelerated network stuff, or at least be optimized to be able to push a lot of packets. But apparently they do not. They are primary built for internet connections where 4 Mb/s is a lot, but not for LAN serving tasks where 100 Mb/s is the standard I guess.Originally Posted by Oleg
To be not serious: We'll just have to wait for the competition in home routers to go into a megaherz race. In five years everyone will have a 4 GHz router for 100,-- Euro which uses more then 100 Watt/h. But at least they will be able to pump a 1 Gb/s pipe full of data from my year 2009 WL-RAID5-HDD while I'm playing the latest games on it with 200+ frames/s![]()
It has nothing except integrated ethernet controller.Originally Posted by Styno
Hmm, that should bring the WL-500gx (Deluxe) to around 5.5 Mb/s second (Assuming it has the same ALU's but at 200MHz CPU instead of 125 MHz for WL-500g and WL-HDD).Originally Posted by Oleg
I will definitely try, but I think it's the ethernet nic driver which needs a boost. Although what I can imagine is that hdd in pio mode terribly slows down the nic.Originally Posted by Oleg
A while ago I did some measurements:
- Raw write speed to HDD is ~4.5mB/s and read speed ~9.5mB/s (measured by dd from and to /dev/zero)
- The NFS read/write speeds are ~2mB/s (direct 100mbs full duplux connect).
From this I more or less concluded that it is the nic driver to blame but who knows.
Improving performance is high up on my priority list and I will start work as soon as samba 3.0.7 is running stable on the wl-hdd.
Try running epi_ttcp using something like this:Originally Posted by JOCKYW2001
This will push the entire file to your host using udp (actually to nothing) and you will get maximum samba speed expectation (nfs should be a bit faster)...Code:epi_ttcp -t -v -u your_host_name < very_large_file_on_the_hdd
Check the /proc/loadavg during the large transfer to/from /dev/null to check for dma/pio. If you see something like 1.0 - then it's definitely pio.Originally Posted by JOCKYW2001
Some numbers:
Transferring 16MB data (mostly kernel space, everything is cached):
Transferring cached data from RAM, interacting with user space - pipes, etc (mostly samba alike)Code:[root@wl500g root]$ epi_ttcp -t -s -v -u 192.168.0.1 ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5010 ttcp-t: start time Tue Oct 26 18:32:35 2004 ttcp-t: File-Descriptor 0x3 Opened sockbufsize=32767, # udp sender -> 192.168.0.1 # ttcp-t: 16777216 bytes in 4.593677 real seconds = 3.483 MB/sec +++ ttcp-t: 16777216 bytes in 4.600000 cpu seconds = 3.478 MB/cpu sec ttcp-t: 2054 I/O calls, 2.236 msec(real)/call, 2.240 msec(cpu)/call ttcp-t: 0.060000user 4.540000sys 0:04real 100.1% 0i+0d 0maxrss 1+0pf 0+0csw ttcp-t: buffer address 0x10008000 ttcp-t: File-Descriptor fd 0x3 Closed ttcp done.
transferring firmware image (wait cycles are added by slow flash)Code:[root@wl500g root]$ epi_ttcp -t -v -u 192.168.0.1 < /tmp/test ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5010 ttcp-t: start time Tue Oct 26 18:30:50 2004 ttcp-t: File-Descriptor 0x3 Opened sockbufsize=32767, # udp sender -> 192.168.0.1 # ttcp-t: 3801552 bytes in 1.280250 real seconds = 2.832 MB/sec +++ ttcp-t: 3801552 bytes in 1.280000 cpu seconds = 2.832 MB/cpu sec ttcp-t: 470 I/O calls, 2.724 msec(real)/call, 2.723 msec(cpu)/call ttcp-t: 0.000000user 1.280000sys 0:01real 100.0% 0i+0d 0maxrss 1+1pf 0+0csw ttcp-t: buffer address 0x10008000 ttcp-t: File-Descriptor fd 0x3 Closed ttcp done.
Transferring big file from usb flash driveCode:[root@wl500g root]$ epi_ttcp -t -v -u 192.168.0.1 < /dev/mtdblock/1 ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5010 ttcp-t: start time Tue Oct 26 18:31:05 2004 ttcp-t: File-Descriptor 0x3 Opened sockbufsize=32767, # udp sender -> 192.168.0.1 # ttcp-t: 3801552 bytes in 2.502654 real seconds = 1.449 MB/sec +++ ttcp-t: 3801552 bytes in 1.370000 cpu seconds = 2.646 MB/cpu sec ttcp-t: 470 I/O calls, 5.325 msec(real)/call, 2.915 msec(cpu)/call ttcp-t: 0.030000user 1.340000sys 0:02real 54.7% 0i+0d 0maxrss 1+1pf 0+0csw ttcp-t: buffer address 0x10008000 ttcp-t: File-Descriptor fd 0x3 Closed ttcp done.
Code:[root@wl500g root]$ epi_ttcp -t -v -u 192.168.0.1 < /tmp/harddisk/hydravision-3-20-2020.exe ttcp-t: buflen=8192, nbuf=2048, align=16384/0, port=5010 ttcp-t: start time Tue Oct 26 18:33:24 2004 ttcp-t: File-Descriptor 0x3 Opened sockbufsize=32767, # udp sender -> 192.168.0.1 # ttcp-t: 11642283 bytes in 19.597037 real seconds = 580.160 KB/sec +++ ttcp-t: 11642283 bytes in 4.490000 cpu seconds = 2.473 MB/cpu sec ttcp-t: 1428 I/O calls, 13.723 msec(real)/call, 3.144 msec(cpu)/call ttcp-t: 0.040000user 4.450000sys 0:19real 22.9% 0i+0d 0maxrss 2+1pf 0+0csw ttcp-t: buffer address 0x10008000 ttcp-t: File-Descriptor fd 0x3 Closed ttcp done.
It's become really offtopic.![]()
Yet another thing: USB is driven by dma:
As you see CPU was idle most of the time (user + sys < real).Code:[root@wl500g root]$ time dd if=/tmp/harddisk/hydravision-3-20-2020.exe of=/dev/null 22736+1 records in 22736+1 records out real 0m 16.16s user 0m 0.19s sys 0m 1.14s
But very interestingOriginally Posted by Oleg
I have some problems understanding the figures you just gave with ttcp-t, but if I understand right, mem to mem copy over TCP/IP gives 3.6 MB/s. Thats not much and probably mostly CPU bound I guess. If its CPU bound then sending data using UDP might help a lot, because it requires much less CPU power. Using a TFTP server might speed up the transferrate a bit in that case.
In fact, 3.6 MB looks like no memory copy at all (but it should be one copy from user space to kernel) - ttcp just sends the same data over and over and it's cached.Originally Posted by Styno
NFS uses udp, kernel space nfs does not perform mem copy at all.Thats not much and probably mostly CPU bound I guess. If its CPU bound then sending data using UDP might help a lot, because it requires much less CPU power.
Well, tftp is really limited and all implementations are running in the user space.Using a TFTP server might speed up the transferrate a bit in that case.
Also, routing is running at the same 3.5 MB speed (no copy, kernel space only).
Ok, I stay out of this discussion![]()
Look at this. My drive is in UDMA2 mode, which is default firmware setting.Originally Posted by Oleg
I guess there is not much more we can do about improving IDE speed.
Perhaps the focus should be on the ethernet driver?
Code:# ../hdparm.mipsel -i /dev/ide/host0/bus0/target0/lun0/disc /dev/ide/host0/bus0/target0/lun0/disc: Model=FUJITSU MHT2080AT, FwRev=0022, SerialNo=NN5AT4915M5H Config={ HardSect NotMFM HdSw>15uSec Fixed DTR>10Mbs } RawCHS=16383/16/63, TrkSize=0, SectSize=0, ECCbytes=4 BuffType=DualPortCache, BuffSize=8192kB, MaxMultSect=16, MultSect=16 CurCHS=16383/16/63, CurSects=16514064, LBA=yes, LBAsects=156301488 IORDY=yes, tPIO={min:240,w/IORDY:120}, tDMA={min:120,rec:120} PIO modes: pio0 pio1 pio2 pio3 pio4 DMA modes: mdma0 mdma1 mdma2 UDMA modes: udma0 udma1 *udma2 udma3 udma4 udma5 AdvancedPM=yes: mode=0x80 (128) WriteCache=enabled Drive conforms to: ATA/ATAPI-6 T13 1410D revision 3a: * signifies the current active mode
