Page 3 of 64 FirstFirst 123451353 ... LastLast
Results 31 to 45 of 958
Thread: [HowTo] Install and configure Oleg's firmware
    Sep 2007
    Netherlands
    I didn't follow the whole tut.
    I didn't format the hdd in the same way, but I've made partitions:
    swap (ca 500mb)
    programs (/opt, ca 500mb, ext3)
    data (tmp/harddisk/part1,ext3)
    data (tmp/harddisk/part2, ntfs, some data that I want on ntfs)
    I use the startup script (4b) with some chances in the mounting part
    didn't do:
    4a. partition and format HDD
    7. Tools (optional)
    8. CRON
    9. TRANSMISSION (want to use samba 1th maybe later)
    9b. Change Syslog settings
    Didn't go further then this jet.
    edit:
    1. run /opt/etc/init.d/S80samba and post result
    [admin@WL500gp root]$ /opt/etc/init.d/S80samba
    Starting smbd:
    Starting nmbd:
    2. post output of "ps axf"
    [admin@WL500gp root]$ ps axf
    BusyBox v1.1.3 (2007.01.01-14:37+0000) multi-call binary
    Usage: ps
    3. post the latest content of the log: /opt/var/log/messages
    I don't have a log "messages" at that location. I do have a dir named "samba" and in this dir a file log.smbd
    latest content of this log is:
    [2007/09/24 22:09:14, 0] source/smbd/server.c:main(835)
    standard input is not a socket, assuming -D option
    [2007/09/26 00:19:00, 0] source/smbd/server.c:main(835)
    [2007/09/26 00:19:13, 0] source/smbd/server.c:main(835)
    edit2
    maybe also helpful:
    found another logfile /opt/var/samba/nmbd
    last part is
    [2007/09/26 00:29:26, 0] source/nmbd/nmbd.c:main(795)
    Netbios nameserver version 2.2.12 started.
    Copyright Andrew Tridgell and the Samba Team 1994-2002
    [2007/09/26 00:29:30, 0] source/nmbd/nmbd_responserecordsdb.c:find_response_reco
    rd(235)
    find_response_record: response packet id 6592 received with no matching record
    [2007/09/26 18:07:26, 0] source/nmbd/nmbd.c:main(795)
    [2007/09/26 18:07:30, 0] source/nmbd/nmbd_responserecordsdb.c:find_response_reco
    rd(235)
    find_response_record: response packet id 4588 received with no matching record
    and this log:
    /opt/var/samba/log.smbd
    last part:
    [2007/09/26 00:31:07, 0] source/smbd/server.c:main(791)
    smbd version 2.2.12 started.
    Copyright Andrew Tridgell and the Samba Team 1992-2002
    [2007/09/26 18:07:26, 0] source/smbd/server.c:main(791)
    Feb 2005
    Germany - Frankfurt
    "ps axf" will not work. Post result of a simple "ps".
    "ps" will show you the running processes. There should be s- and nmbd.
    Also make sure that samba in the original webinterface is DISabled.
    Do the following:
    - Disable Samba in Webinterface (if it isn't already)
    - reboot router
    - post result of "ps"
    wengi
    WhiteAss, you should read my tutorial for a working Samba3.
    However... to see the processes, type:
    ps (if you don't have 7. Tools (optional))
    Or:
    ps aux
    ps -ef
    if you installed 7. Tools (optional).
    Sep 2007
    Netherlands
    I'm trying to install samba on the way explained by arise for the moment.
    will post my questions over there.
    edit:
    Came back on this.
    after folowing the tut of arise my router didn't work so good anymore.
    Will follow this tut again from the begin (exept for the fdisk/fromat part)
    Sep 2007
    Netherlands
    I began from scratch again
    I can conf the standard samba which is there wit the oleg firmware.
    149 admin 892 S /usr/sbin/smbd -D
    151 admin 964 S /usr/sbin/nmbd -D
    This is v1.x (don't know the exact version)
    I want to use the web interface (swat) so I'v to install samba2.
    When I install samba 2 (the one in this tut) I can use the web interface but samba doesn't work then (even without the web interface an with the same conf as samba 1)
    smbd and smbd just won't run and I can't find out what is wrong.
    Feb 2005
    Germany - Frankfurt
    So the fun starts again:
    try to start manually and give us the logs....
    i need input
    wengi
    PS: I am on vacation from thursday on. We need to solve this quickly or anyone else has to help you.
    Chinese character
    I am using SAMBA 2 but not working good on chinese character file name (both samba2 and vsftp). I read the article in here saying need Samba 3
    http://www.nslu2-linux.org/wiki/Optware/Samba
    But some artical saying need a codepage.....
    I search this for long but still can't find the exit.... Any good people can help please : <
    Quote Originally Posted by wengi View Post
    9. TRANSMISSION (The torrent Client)
    Transmission works really strange
    when i open http://192.168.1.1:8080/cgi-bin/transmission.cgi i get
    syslog: /opt/var/log/messages unavailable for transfer stats!
    although I did everything just like in howto
    when i click watchdog i get
    /opt/sbin/transmission_watchdog: kill: 306: (524) - Operation not permitted grep: /tmp/harddisk/torrent/work/my.torrent/.status: No such file or directory
    when i select torrent in list and click push i get
    transmission.cgi: kill: 9: (524) - Operation not permitted
    Any ideas?
    Update 1
    Right after restart transmission_watchdog doesn't appear.
    If it's started manually i get a lot of instatnces
      183 admin       468 S   upnp -D -L br0 -W vlan1
      214 admin      1696 S   transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      217 admin      1700 S   transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      218 admin      1700 S   transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      219 admin      1700 S   transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      220 admin      1700 R   transmissiond -p 65534 -w 300 -u -1 -d -1 -i /opt/var/run/transmission.pid /tmp/harddisk/torrent/active-torrents.txt
      222 admin       412 R   ps
    Does it matter?
    Hardware: WL-500gp 1.9.2.7-7g + powered USB hub (WD Passport 120GB) + USB HP LazerJet 1010
    Software: transmission (BT-client) by wengie's manual + russian names fixing script | http/ftp download with web-interface ADOS by DINI (uninstalled) | rsnapshot - incremental backup utility using rsync (english, ðóññêèé) (uninstalled) | lighttpd (uninstalled) |samba2
    Feb 2005
    Germany - Frankfurt
    transmission is not started directly after restart. It normaly depends on the cron entry. E.g. if the watchdog is started hourly, transmission will be started the next full hour after thr reboot.
    If you want to start it directly after the reboot: Add transmission_watchdog to your post-boot.
    There are always multiple instances of transmission running.
    This is normal.
    For the errors: try another torrent. Maybe the file was damaged. How do you copy the torrents? wget in ssh / ftp / samba? I normaly use wget in ssh session.
    wengi
    PS: please edit your post and delete the torrent name or use a legal torrent.
    This is normal.
    wengi
    don't know what was the problem. I just did everything by your guide from the start and it worked - first time I combined yours and olegI's.
    And I was a dumb at linux - now situation improved.
    Thanks for your great manual. What about putting it into wiki?
    Feb 2005
    Germany - Frankfurt
    Good to know its working now
    wengi
    wengi
    may you can help me with this? http://wl500g.info/showthread.php?p=67114#post67114
    Feb 2005
    Germany - Frankfurt
    Hi Aramaki,
    i already read your post but unfortunately am not able to help you.
    wengi
    Hi Aramaki,
    wengi
    Anyway thx
    A little note regarding wengi's "14. Automate SSH login"
    So, I've created the pair of keys for automatic login.
    Then I run
    vi /usr/local/root/.ssh/authorized_keys
    and right click of my mouse in order to paste text in the putty window.
    Then I pressed exactly the next keys:
    [Esc]
    :wq!
    [Enter]
    ... and I tried to login and didn't worked as expected.
    Found out later in Midnight Commander viewer that the first later from "ssh-rsa ..." was missing and I had only "sh-rsa ...".
    I've added the missing "s" and it worked like a charm.
    Don't know if it's my problem (I'm a stupid user sometimes ) or is a bug or something. Just in case anyone gets in the same problem as me...
  1. [Howto] Install DLNA media servers for Oleg firmware
    By ecaddict in forum WL-500gP Tutorials
    Last Post: 06-06-2017, 07:40
  2. Replies: 24
    Last Post: 05-05-2015, 07:42
  3. Replies: 28
    Last Post: 02-06-2013, 20:58
  4. Replies: 6
    Last Post: 21-09-2012, 17:06
  5. [Howto] Install kernel modules for Oleg firmware
    Last Post: 05-12-2011, 16:18
