Did you plan release new version firmware ?
If not, give please link for source code.
'traceroute' command
where is it?
To my knowledge there is no traceroute command currently supported. It's been requested as a new feature (http://wl500g.info/showthread.php?p=64203).
no answer for my question?
i found source code on this page
Building your own 1.0.7.8 based firmware image from source
Its latest source with all fixes ?
Hello, I'm be having the Asus WL 700ge since it came out and I been having problems using it for that it said ever since. I'm a newbie about anything that its regarding Linux. I wanted to know if there a ultimate Firmware out that one could just install it and it work like it should have.
1.A good bittorrent
2.A good downloader for the people that use sites like Rapid Share
3.A easy way to hold a website
4.Easy to share files locally and over the internet
5.A better Multimedia Server for the Xbox 360 and the PS3
6.Share file by wifi
I just have simple needs.
This feature would be great:
An ability to boot custom kernel (and drivers) from HDD directly from bootloader or via kexec (I don't know whether it has support for ARM now) before normal boot continues. With normal boot when there is no HDD.
Configuration so that Xbox will not complain that NAT is Restricted, I have more than 2 Xbox'es and there is only 1 DMZ, so that wont work.
Easier reading logs of incoming and outgoing packets.
Easier editing opening ports (now have to delete entry and add new)
Enable name forwarding to an IP, (ie. abc.wl500g.info -> 192.168.1.123, def.wl500g.into -> 192.168.1.22)
