found the "Segmentation fault" error but have one more q.
Is there some tuning that not only IE display the graph correct ?
Me have some prob with Firefox.
Best Regards
Hallo all
is this allstats working on a gx with wl500g-1.9.2.7-5a ?
if i start account_traffic.sh me got a error from sed
and the cgi display a "Segmentation fault"Code:# ./account_traffic.sh setting/updating usage counter files sed: bad format in substitution expression sed: bad format in substitution expression sed: bad format in substitution expression sed: bad format in substitution expression sedsed: bad format in substitution expression : bad format in substitution expression append usage to day dat files tailing counter files finished.
Anyone with the same error and had fixed this ?
Best Regards
Best Regards
Plese helpCode:[admin@WL500g accounting]$ ./add_iptables.sh ./add_iptables.sh: 3: awk: not found [admin@WL500g accounting]$
Upgrade to latest firmware.Originally Posted by connic
I have in WL500g firmvare version 1.9.2.7-4. This wersion it not supports?Originally Posted by Oleg
Now notification:
Code:[admin@WL500g accounting]$ ./add_iptables.sh ./add_iptables.sh: 3: /tmp/harddisk/accounting: Permission denied
Upgrade to 1.9.2.7-6b.Originally Posted by connic
With firmware 1.9.2.7-6b:Originally Posted by Oleg
where's AWK applet? In file "init.sh" is line with text:Code:[admin@WL500g accounting]$ ls account_traffic.sh graph_day.awk mkcron.sh accounting_v2.tar graph_month.awk monthtot.sh add_iptables.sh httpd.conf rem_iptables.sh daytot.sh init.sh usage.sh graph_all.awk ipaddress.txt [admin@WL500g accounting]$ ./add_iptables.sh ./add_iptables.sh: 3: /tmp/harddisk/accounting:Permission denied
# pointer to AWK applet
AWK="AWK"
I Attache main files for verification.
Just remove the following lines from add_iptables.sh, because they are not used:
Have you installed the scripts in the /tmp/harddisk/accounting directory? If not, change installation directory in init.sh accordingly.Code:# ipnumbers of PC's in LAN ipnumbers=`cat $accountdir/ipaddress.txt| $AWK '{print $2 }'`
BTW: I am working at a graphical version based on rddtools. It generates nice usage graphs in gif format. Will post things soon!
Ahh, thats cool if you can make one with rddtools )
Regards
There is allready something for openwrt and rrd
http://wiki.freifunk-leipzig.public-...tzwerkStatisik
I tried to install these packages. Everything works fine, except the libpng or other graphical libraries are not included. Any feature leading to real graphics causes a 'segmentation fault'. Therefore, I compiled the rrdtool myself and used static linking to the libraries. Bin's included.
Later I will post some scripts to log traffic to different pc's in lan (based on add_iptables.sh). The graphs are generated on the asus and then I FTP the resulting graphs and databases regularly to a webserver with a proper access to the internet.
I want to use this feature, too.
But what am I have to do to install this?
Should I use the wiki-instructions?
sodb, is your tool ready to use?
(How to use this?)
better is using RRD tools from www.macsat.com . Look at http://www.home.karneval.cz/0220603501/zdenek . There is showed what can you do do with rrd tool. But it is only in Czech language. But you will understand it. Maybe :-)Originally Posted by britnet
Excelent work, this is what I need.
Can you post more details of how do you do this? Scripts. Do you change iptables?
please KAMILEK, pleaseee .. I would like to have the same possibilities to put the individual IPs into the graph .... As a normal RRDToll with the WAN/LAN/WLAN accounting working fine, but yours are BETTER
Prosim, hodne prosim
WiZi from CB
