Results 1 to 15 of 31
Thread: Firmware v9.8.2.1 BETA
    Nov 2003
    Eindhoven
    WARNING: BETA VERSION
    TRY AT YOUR OWN RISK!
    DO NOT UPGRADE UNLESS YOU KNOW WHAT YOU ARE DOING
    DOWNGRADE IS NOT EASILY POSSIBLE!!
    Changelog:
    nothing official: QOS supported is in webinterface now untested, webcam PWC driver updated to 8.11
    official leaked:
    Chg: Not write eeprom bits(WL500g.Deluxe Only) (in 1.8.2.1)
    Fixed: WL500gx setting file malfunction(WL500g.Deluxe Only) (in 1.8.2.0 already)
    important!!
    When upgrading from 1.7.x.x based firmware: you MUST Reset your WL500g to defaults via the restore button at the back after upgrading to this firmware!
    you do not have to do this when you upgrade from 1.8.x.x based firmware!
    but we recommend you to do a restore to defaults
    Do not import saved settings from older/other firmwares! this can cause unstability to your device
    Mirror @ Chupa.nl:
    http://files.wl500g.info/asus/wl500g...9.8.2.1_EN.zip
    Apr 2004
    Netherlands
    Cool
    Hey! That QoS thinghy configurable from the webinterface sounds great, but I guess it gives you the opportunity to:
    - enter the script parameters nr. 5 till 9,
    - set min/max parameters
    - and to enable/disable it.
    Am I right?
    Nice feature for the webinterface, but nothing more then that. Setting it up from telnet isn't that difficult....Besides that, it gives you only control to shape TCP traffic, nothing on UDP.
    Anyway, it's userfriendly that counts
    Nov 2003
    Eindhoven
    Am I right?
    no idea.. this is an implementation by asus, i have no idea what they are using at all. and I can't check websetup now because my main wl500g won't forward port 80 to the wl500g behind it
  4. Question
    Where it come from ?
    I don't see it on asus website or on their ftp ?
    Nov 2003
    Eindhoven
    Quote Originally Posted by chris.delarue
    Asus never publishes beta firmwares on their ftp
    but it's from Asus
    ..... funny WAN port dies problem fixed with this release
    Downloading at 800+KByte/sec for hours and hours and never die. Before it dies in 10 to 30 min.
    Give it a try if you have the same problem.... I am much happier with Asus now....
    Name cant be changed ?
    hey i cant seem to find the place where i can change the login name.
    u know instead of: admin
    i could change it before, i think it was under the change password menu.
    Nov 2003
    Eindhoven
    Quote Originally Posted by mr.destroyer
    it's a custom feature which I made sometime
    so only available in custom firmware
    could anyone tell me have or not reset/reboot problem with this version??
    i tried. reset problem haven't fix...
  1. Firmware v1.9.3.9 BETA
    By Antiloop in forum WL-530g Firmware Releases
    Last Post: 04-06-2006, 13:38
  2. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-300g Firmware Releases
    Last Post: 18-11-2005, 09:49
  3. Firmware v1.9.3.6 BETA
    Last Post: 27-04-2005, 07:54
  4. Firmware v1.9.3.6 BETA
    By Antiloop in forum WL-500gx Firmware Releases
    Last Post: 20-03-2005, 02:40
  5. Firmware v1.7.5.7 BETA
    Last Post: 12-05-2004, 23:03
